CC Problem Beyond the Standard Model
In summary, the conversation discusses the cosmological constant problem and possible solutions to it. The problem can be seen as either internal, where changes are needed within the current frameworks of GR and QFT, or external, where an extended framework is needed to address the issue. The link between GR and QFT is also considered problematic, either due to limited understanding or the need for an extended framework. The conversation also mentions Schwinger's source theory as a potential solution to the 120 magnitude discrepancy in vacuum energy density. Other related issues, such as the Hierarchy Problem and the role of mass in both the cosmological constant problem and the Higgs, are also mentioned. These problems are considered to be the most severe in physics today.
lucas_
413
23
Which of the following do you prefer as possible solution to the cosmological constant problem or why QFT computes vacuum energy density that is 120 magnitude more than from observational data? Sometimes I think the metric (1.a) needs to change, but on other days I think QFT needs to change (2.a).. the CC problem would indeed be directly relevant to search for physics beyond the standard model.
http://arxiv.org/pdf/hep-th/0012253v1.pdf
1. A modification of GR. The problem could be either(a) ‘internal’ in the sense that a change is needed in the GR formalism itself (e.g. changing the role of the metric), or
(b) ‘external’ in the sense that GR is still considered effectively correct, but that it needs to be embedded in an extended framework to address the question (e.g. quantum cosmology).
2. A modification of QFT. Again, the problem could be either(a) ‘internal’ in the sense that a change in, or a reinterpretation of, the QFT formalism which gives rise to the vacuum energy is needed (for instance through Schwinger’s source theory), or
(b) ‘external’ in the sense that QFT (the Standard Model) is considered effectively correct as a low energy theory, but needs to be embedded in an extended framework to address the question (e.g. supersymmetry).
3. The link between GR and QFT is problematic. Once more, we see at least two
ways in which this may be the case, either the problem is
(a) ‘internal’ in the sense that the link cannot even be discussed properly due to our limited understanding of the coupling between GR and QFT (e.g. QFT in curved spacetime, and back-reaction), or
(b) ‘external’ in the sense that we due to the limited understanding of the coupling between GR and QFT ought to postpone the problem until we have a theory in which the link is embedded in an extended framework for both GR and QFT since only in such a theory will the problem be completely well posed (e.g. string theory)
Schwinger’s source theory is that in the absence of matter and measurement settings, there are no quantum fields avoiding the 120 magnitude discrepancy, how many even consider this possibility?
Can you add others not mentioned above?
In the Hierarchy Problem. It's related to mass too or why Planck mass fluctuations don't make the higgs much heavier. In the Cosmological Constant problem, it is mass too coming from the quantum fluctuations that are 120 magnitude off to observations. They have in common mass from virtual fluctuations.. won't that give constrains to solutions to both? These are the most severe problems in physics today. What can you guys say about this.
Related to CC Problem Beyond the Standard Model
1. What is the "CC Problem Beyond the Standard Model"?
The "CC Problem Beyond the Standard Model" refers to the issue of trying to reconcile the observed value of the cosmological constant (CC) with the predictions of the Standard Model of particle physics. The CC is a term in Einstein's theory of general relativity that describes the energy density of the vacuum of space.
2. What is the Standard Model of particle physics?
The Standard Model is a theory that describes the fundamental particles and their interactions that make up the universe. It has been incredibly successful in predicting and explaining the behavior of subatomic particles and their interactions.
3. Why is the CC Problem considered a major challenge for physicists?
The CC Problem is considered a major challenge because the observed value of the CC is incredibly small compared to what is predicted by the Standard Model. This discrepancy is known as the "CC Problem" and it has been a longstanding mystery in physics.
4. What are some proposed solutions to the CC Problem?
Some proposed solutions to the CC Problem include modifying the Standard Model to include new particles or interactions, introducing new theories such as supersymmetry, and considering the possibility of a multiverse where the CC can vary in different regions of space.
5. How is the CC Problem being studied and tested?
The CC Problem is being studied and tested through a variety of experiments in particle physics, astrophysics, and cosmology. These include experiments at particle accelerators, observations of the cosmic microwave background, and studies of the large-scale structure of the universe. Scientists are also working on theoretical models and simulations to better understand the nature of the CC and its potential solutions.
  • Beyond the Standard Models
  • Science and Math Textbooks
  • Quantum Interpretations and Foundations
