MHB Cdf, expectation, and variance of a random continuous variable
The probability density function f(x) is defined as b[1-(4x/10-6/10)^2] for 1.5 < x < 4, with b calculated as 3/5 to ensure it is a valid density function. The cumulative distribution function F(x) is derived as (-4x^3/125 + 18x^2/125 + 48x/125 - 99/125). The expectation E[X] is found to be 2.4375, while the variance Var[X] is calculated as 0.3711. To find the probability that X is within one standard deviation from the mean, the integral of f(x) over the interval defined by E[X] ± σ[X] is necessary.
marcadams267
Given the probability density function f(x) = b[1-(4x/10-6/10)^2] for 1.5 < x <4. and f(x) = 0 elsewhere.
1. What is the value of b such that f(x) becomes a valid density function
2. What is the cumulative distribution function F(x) of f(x)
3. What is the Expectation of X, E[X]
4. What is the Variance of X, Var[X]
5. What is the probability that X is within one standard deviation from the meanSo far, I've gotten b by integrating the function from 1.5 to 4 and setting it equal to 1, thus getting b = 3/5.
Plugging b into the function, I also integrated it from 1.5 to x, to get a cdf of (-4x^3/125 + 18x^2/125 + 48x/125 - 99/125)
To get the E[X], I integrated f(x) from 1.5 to 4 to get 2.4375
To solve for the variance i used the equation E[X^2] - E[X]^2 and got 0.3711
However, help would be appreciated for number 5 as I am not even sure where to start on that one.
Hi marcadams267, welcome to MHB!
The probability that $X$ is between two arbitrary values $a_1 \le a_2$ is:
$$P(a_1<X<a_2)=\int_{a_1}^{a_2}f(x)\,dx$$
The standard deviation $\sigma[X]$ is the square root of the variance:
$$\sigma[X]=\sqrt{\operatorname{Var}[X]}$$
So in this case:
$$P(\text{X is within one standard deviation from the mean}) \\= P(E[X]-\sigma[X]<X<E[X]+\sigma[X]) \\= \int_{E[X]-\sigma[X]}^{E[X]+\sigma[X]} f(x)\,dx$$
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
