big man
- 254
- 1
Hi
I have been having a problem with a section of my code in the macro that I've created. The problem is that the formulae that I want to use aren't working and soe I get a "##Name" error in the cells where the formula is supposed to have worked.
Patientrange = Range(PatAgeLet & "2" & ":" & PatAgeLet & Locator).Address
For Count = 2 To 6
FormulaRange1 = Range(Infocol & Count).Offset(0, 1).Address
FormulaRange2 = Range(Infocol & Count).Offset(0, 2).Address
NewRange = Range(FormulaRange1 & ":" & FormulaRange2).Select
With Selection
.NumberFormat = "0"
.HorizontalAlignment = xlCenter
.VerticalAlignment = xlBottom
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.ShrinkToFit = False
.ReadingOrder = xlContext
.MergeCells = True
End With
If Count = 2 Then
ActiveCell.Formula = "=MIN(PatientRange)"
ElseIf Count = 3 Then
ActiveCell.Formula = "=MAX(Patientrange)"
ElseIf Count = 4 Then
ActiveCell.Formula = "=MEDIAN(Patientrange)"
ElseIf Count = 5 Then
ActiveCell.Value = Rangarrsize
ElseIf Count = 6 Then
ActiveCell.Formula = "=COUNTIF(Patientrange, ""<=40"")"
End If
Next Count
As you can see by this code Patientrange is a dynamic range and so this is the range that I want to use in my formulae. However, it just isn't working at all.
Any suggestions??
For Count = 2 To 6
With Selection
.NumberFormat = "0"
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.MergeCells = True
End With
If Count = 2 Then
End If
Next Count
Any suggestions??
