Cellular or smartphone calls / texts / data when on a moving train
Cellular service and data reliability for smartphone users on moving passenger trains can be inconsistent, primarily depending on the train's location and coverage in rural areas. Users may experience service interruptions, particularly when trying to send photos or upload data, as these tasks require stable connections. Sending images via email or cloud storage while in transit can lead to data plan exhaustion due to repeated failed attempts to transmit when service drops. The challenges of maintaining a stable connection are exacerbated by multi-path reflections from nearby structures, which complicate signal reception, especially for moving devices. While voice calls may be manageable due to the nature of data transmission, sending larger files like images can result in failures due to brief signal loss. Modern mobile networks, particularly 4G and 5G, are designed to handle multi-path issues better than previous generations, but high speeds and frequent obstructions on trains can still lead to poor connectivity. Users are advised to check their carrier's coverage maps to understand service availability along their routes.
symbolipoint
Education Advisor
TL;DR Summary
Smartphone users on moving train receive good cellular service?
Do smartphone users get good cellular service as well as good cellular data while on a moving passenger train? This is assuming no wi-fi available.
Computer science news on Phys.org
It depends on where the train is and whether there is coverage in rural areas the train passes through.
Likes symbolipoint
My wife had an odd experience with her cell phone and sending a photo while on a national parks tour. Their tour bus would go in an out of service areas. While on the bus, she tried to send me a few photos but the sending would fail when she lost service and try again when service was strong enough and then fail...
We got an error message email that said we had exhausted our cell data plan and that when we discovered what had happened.
That tells us something. Restrict data usage while using cell/smartphone on moving train. One thing best to avoid, is to try to send picture attachments in email. Another thing best to not do is upload images to cloud storage. Waiting until you're in a stable wi-fi location would be the way to go.
  • Haha
Likes jedishrfu and anorlunda
Yes, that's what we did. This happened quite a few years ago for us.
In addition to poor signal strength issues in rural areas, the multi-path reflections will play havoc with the cell signals when there are reflecting objects in the area (like buildings, bridges, etc. Multi-path is hard enough to deal with for a stationary TX/RX system, let alone when the RX device is moving through multiple reflection zones (at several time a second...
So the meaning is, cellular data while on a moving train will likely be spotty or absent. I guess this also means that travelers who are on the same moving train but in different train cars will often not be able to call or text each other.
I believe so. But in a moving car, we can often carry on voice calls, so maybe the cell companies have figured out ways to combat the multi-path issues (make the packets small enough to make it through the multi-path flutter...
In a voice call, a 1 second dropout may be hard to notice. But when sending a picture, it may be enough to spoil the upload and make it start over.
I believe that Fourth and Fifth Generation mobile systems are designed to work with multipath and even to exploit it to actually increase performance by using diversity. A mobile can communicate with more than one base station simultaneously, for instance. However the high speed of a train plus the frequent obstructions to propagation will mean frequent loss of signal, which I have found worse than with road travel. When at a remote location with no apparent mobile coverage, I have found that I can send a text via reflection from a passing aircraft. Text is very efficient for getting a quick burst through.
Likes symbolipoint and berkeman
Does your provider provide a map of coverage? I know with mine, Vodafone NZ, you can see signal coverage for 2G / 3G / 4G and areas now privy to 5G.
Good question and worth checking. I believe the carrier (the provider) does give a coverage map. Worth a recheck!
