Center of gravity/moment of inertia
In summary: So for your example, if the axis is through the center of the board, then the moment of inertia for the board would be 1/12 (15^2+8^2) = 82.08 and the moment of inertia for the fan would be 1/12 (15^2+2^2) = 39.58. The total moment of inertia would then be 82.08 + 39.58 = 121.66.
Musica
I am doing a mini hovercraft project. Regarding my design, I plan to place the fan (LIFT) in the middle of a rectangular styrofoam board (15 inches by 8inches). The position of my fan would be (x=7.5, y=4in); this would also be my center of gravity. My origin (coordinate) is at the corner of the styrofoam board. My thrust fan will be placed closer to the origin.
I would like to ask if I do need to include the mass of the styrofoam board (where I will placed all my components)? If yes, what would be its position from the origin.
Another thing, concerning the moment of inertial, I know to get it for a rectangular plane (uniform volume and mass), it is I=1/12 (length^2+width^2) . But with the components to be placed with different masses and volumes, how will I get the moment of inertia? I decided my center of gravity is at the middle of the styrofoam.
Assuming your question concerns including the mass of the styrofoam when working out the moment of inertia, then yes, you should include it. You can consider the entire mass of the board to be located at its centre of mass, which is at the centre of the board since it is uniform.
The key thing to remember for your second question is that moments of inertia are additive about a common axis. That is to say, if you have a set of objects each with a different moment of inertia about some axis, then the total moment of inertia about that same axis is the sum of each individual moment.
Thanks for the reply
I need more explanation on this part
For example, I would attached only a thrust fan, position is (x=7.5 ,y=2 in), at the back of the rectangular styrofoam board. Let's assume the fan is a rectangular plane as well.
I wanted to get the moment of inertia. So, how will I compute it?
So itf the formula is : total moment of inertia = moment of board on its own axis+ moment of fan on its own axis
My attempt:
total moment of inertia= 1/12 (length of board^2+width of board^2) + 1/12 (length of fan^2+width of fan^2)
I am not sure so the position of the fan relative to the center of mass of the sytro board would not matter for moment of inertia
Not on its own axis. Moments of inertia are only additive about a common axis. So you can't just add the moments of inertia of the two objects about their own axes, you have to pick an axis (wherever you want) and then add the moments of inertia of both objects around that axis.
FAQ: Center of gravity/moment of inertia
What is the difference between center of gravity and moment of inertia?
The center of gravity is the point at which the weight of an object is evenly distributed and the object is in equilibrium. The moment of inertia, on the other hand, is a measure of an object's resistance to changes in its rotational motion.
How do you calculate the center of gravity/moment of inertia of an object?
The center of gravity can be calculated by finding the weighted average of all the individual masses in an object. The moment of inertia can be calculated using the formula I = Σmr², where m is the mass of each individual component and r is the distance from the axis of rotation.
Why is knowing the center of gravity/moment of inertia important in physics?
Knowing the center of gravity and moment of inertia is important in physics because it helps determine an object's stability and how it will behave when subjected to external forces. This information is crucial in designing structures and predicting their movements.
Does the center of gravity/moment of inertia change for different objects?
Yes, the center of gravity and moment of inertia can vary for different objects depending on their shape, size, and mass distribution. For example, a long, thin object will have a different center of gravity and moment of inertia than a short, wide object.
How does the center of gravity/moment of inertia affect an object's motion?
The center of gravity and moment of inertia play a significant role in an object's rotational motion. The location of the center of gravity determines how an object will rotate, while the moment of inertia affects the speed and ease of rotation. Objects with a lower moment of inertia will rotate more easily than those with a higher moment of inertia.
