Center of Mass DerivationDoubt
In summary, the center of mass is the point where the sum of all torques produced by the masses in a system is equal to zero. This is derived from the concept of a seesaw, where the balance point is determined by the distribution of masses along the seesaw. The term m1r1, etc. in the equation is proportional to the torque produced by each individual mass about a reference point, where r1 is the distance of the mass from the reference. The general equation for center of mass is not derived, but rather defined as the weighted mean of the masses in a system.
zacky_D
Center of Mass Derivation..Doubt :(
Guys,I don't seem to understand how the general equation for Center of mass was derived.I mean,yeah,i get that in a rod,or other symmetric structures,it should lie at the point of symmetry more or less,How waz the general equation derived?m1r1+m2r2+m3r3+...mn rn/m1+m2+m3...etc??..What does the term m1r1 actually mean??:(
McmRcm = m1r1+m2r2+m3r3...+mnrn
:Lets say, i can plug and chug the equation to get an answer to score at test and stuff,but just don't understand the significance of the term m1r1..
This equation is not derived, it is the definition of the centre of mass.
m1r1 = mass of particle 1 x distance of particle 1 from the origin
Cmon..How can you simply define something and just start off? :(..There must be a perfectly valid explanation for why one came up with that definition ryt?:(
The center of mass is simply an elaboration of the concept of a seesaw. If two bodies of equal mass are placed one at each end of a seesaw, the balance point of the system is equidistant between the two bodies, assuming a uniform seesaw beam.
If one of the bodies were twice as massive as the other, the balance point for the seesaw would shift to a point closer to the more massive body on the seesaw.
The term m1r1, etc. is proportional to the torque produced by the mass of body #1 about a convenient reference point, where r1 is the distance of mass 1 from the reference. If one were to calculate all of the torques produced by several bodies about the center of mass of all of the bodies, the sum of these torques would equal zero.
Ohk,i get the see saw bit,so what you are saying is,since we know if net force on Centre of mass is sum of all other forces on the body,we get,Ma(cm)=m1a1+m2a2+...+mnan...And sort of worked back to get that relation between distances,m1r1+m2r2+...?
I think an example would help clear up the situation:
Suppose our seesaw is 10 m long and we wish to balance (or find the center of mass) for two masses, m1 = 5 kg, and m2 = 10 kg. The seesaw beam is massless. The two masses are placed at opposite ends of the seesaw.
We don't know where the balance point might be, so we calculate taking our reference from one end of the seesaw. Our calculation would look like this:
c.o.m. = (1/(5+10) kg) * (5 kg * 0 m + 10 kg * 10 m) = 100 kg-m / 15 kg = 6.67 m
Thus the c.o.m. is located toward the more massive body.
Now, knowing the location of the c.o.m., if we were to calculate the torque of the masses about the c.o.m., we would get the following:
torque = 5 kg * (0-6.67) m + 10 kg * (10 - 6.67) m
= -33.33 kg-m + 33.33 kg-m
torque = 0 kg-m
Related to Center of Mass DerivationDoubt
What is the center of mass?
The center of mass is the point at which an object's mass is evenly distributed in all directions. It is often referred to as the "center of gravity" because it is the point at which an object will balance.
How is the center of mass calculated?
The center of mass can be calculated using the formula (m1r1 + m2r2 + ... + mn rn) / (m1 + m2 + ... + mn), where m is the mass of each individual part and r is the distance from each part to a reference point.
What is the importance of knowing an object's center of mass?
Knowing an object's center of mass is important in understanding its stability and how it will behave when subjected to external forces. It is also useful in determining the motion of objects in systems, such as in physics and engineering.
Can the center of mass be outside of an object?
Yes, the center of mass can be outside of an object if the object has an irregular shape or if its mass is unevenly distributed. However, it will still act as the point at which the object's mass is balanced.
How does the center of mass relate to rotational motion?
The center of mass is the point about which an object will rotate when subjected to a torque. This is because the center of mass is the point at which all the object's mass can be considered to be concentrated for the purpose of calculating its rotational motion.
