Center of Mass for a Bowling Ball
In summary, the conversation discusses the problem of finding the center of mass for a bowling ball with three spherical holes of uniform density. The individual discussing the problem outlines their thought process and possible approaches to solving the problem, including treating the ball as a full object minus the cavities and reducing the problem to simpler forms. The conversation also addresses the complexities of the partial spherical shape of the holes and suggests approximating them as cylinders.
Yoni V
44
Hey everyone!
I recently worked through finding the moment of inertia of a cylinder with a cylindrical cavity off center, and I wish to further deepen my understanding of calculating the center of mass of such objects. So I made up the following problem:
Find the center of mass for a bowling ball of radius R and uniform density, with 3 similar holes characterized as follows:
a. Spherical of radius r.
b. Situated such that their centers are equidistant with distance d (>2r).
c. This is a little tricky for me to explain, because English is not my mother tongue: I want the holes to lie partially outside the ball (like a real bowling ball). Slightly more rigorously speaking, if the ball were a circle, the holes would be circles that intersect the "bowling circle" with right angles.
I hope this description is satisfactory.
Rcm=1/ρVtotal*∑iρVi
Inspired by the cylinder problem, I tried to treat this as a full ball minus the cavities, but there are few key differences to consider that make it a whole lot more difficult:
a. There is more than one cavity.
b. The cavities are aligned with a spherical symmetry rather than a cartesian symmetry, which I find harder to make sense of.
c. There is considerable complexity in the fact that the holes are partial spheres. I could approximate the holes to be half spheres, though I'd rather find the exact solution.
A similar approach would be to add another "phantom" spherical shell with zero mass around the ball, tangent to the continuation of the holes, and then subtract the holes entirely, although then we would need again to subtract the partial phantom leftover, which gets us back to the start.
Another line of thought is to reduce the problem to simpler forms and then build up the real thing:
a. A bowling ball with one hole instead of three, to isolate the partial sphere mess from symmetry issues.
b. Reducing it to 2d.
But even then, I'm still stuck on the partial sphere/circle crux.
Thanks!
Yoni
d>2r? I guess that should be d<2r. And if you don't measure along the curved surface, you even need ##d<\sqrt{3}## (and much smaller for a realistic bowling ball).
That is certainly a good start.
If you can calculate one, the other two are not hard.
You'll need their position relative to some reference frame (like one centered at the center between the three holes)
This effect should be very small for realistic holes. To a first approximation the holes are cylinders. A better approximation considers some tilted end of those cylinders. And if you want to consider deviations from this due to curvature, you first have to find out if the mass distribution and the spherical shape are known well enough to reach this precision at all.
I suggest to start with the cylinders (with some "average" end for the sides where they are open).
Related to Center of Mass for a Bowling Ball
1. What is the center of mass for a bowling ball?
The center of mass for a bowling ball is the point at which the mass of the ball is evenly distributed in all directions. It is the balance point of the ball and is located at the geometric center of the ball.
2. How is the center of mass of a bowling ball determined?
The center of mass of a bowling ball is determined by finding the point of equilibrium between the weight of the ball and the distribution of its mass. This can be done through mathematical calculations or by physically balancing the ball on a pivot point.
3. Does the center of mass of a bowling ball affect its performance?
Yes, the center of mass of a bowling ball plays a crucial role in its performance. The location of the center of mass can impact the ball's stability, hook potential, and overall motion on the lane.
4. Can the center of mass of a bowling ball be changed?
Yes, the center of mass of a bowling ball can be changed by drilling finger holes in specific locations. This changes the distribution of mass in the ball and can alter its overall performance on the lane.
5. How does the shape of a bowling ball affect its center of mass?
The shape of a bowling ball can affect its center of mass by changing the distribution of weight throughout the ball. A ball with a symmetrical shape will have its center of mass in the center of the ball, while an asymmetrical ball may have its center of mass located off-center.
