Center of mass in glass of water
In summary, the conversation discusses a glass with a cylinder on top of a bottom, with water being poured in and the resulting center of mass being calculated. It is found that the lowest center of mass occurs when the water level is at 2.550553126 cm, with the c.o.m. being 1 cm above the water level. A mathematical or physical explanation for this phenomenon is requested.
yomakaflo
So we have a glass consisting of a 10 cm long cylinder on top of a 1 cm long bottom standing on a table. The radius is 3 cm. For every x in [0, 10] we let h(x) be the height of the center of mass when we fill the glass with x cm water. That is, h(x) is the distance from the table to the center of mass.
We have h(x) = (m_b*h_b + m_c*h_c + m_w*h_w) / (m_b + m_c + m_w), with
m_b = mass of bottom = 10 gram
h_b = height of center of mass in bottom = 0.5 cm
m_c = mass of cylinder = 50 gram
h_c = height of center of mass in cylinder = 6 cm
m_w = mass of water = 9*pi*x
h_w = height of center of mass in the water = 1 + x/2 cm
Now the task is to find where h(x) decreases and increases for x in [0, 10].
Which height of water gives the lowest center of mass in the glass, and what is h(x) for that x-value?
By differentiating h(x) I found that x = 2.550553126 makes h(x) be the lowest. h(2.550553126) = 3.550553126. This puzzled me. Why is the center of mass exactly 1 cm over the water level when h(x) is at its lowest? Does someone have a mathematical or physical explanation to this?
When the glass is empty, it has a certain c.o.m. located above the table. Putting a little water in the bottom of the glass will lower the overall c.o.m. of the glass + water a little, but the c.o.m. may still be located above the surface of the water.
You can't really do an analysis of this system unless you know more about the glass and its construction.
Related to Center of mass in glass of water
What is the center of mass in a glass of water?
The center of mass in a glass of water refers to the point where the weight of the glass and water is evenly distributed. It is the average location of all the mass in the glass and is a crucial concept in understanding the stability and balance of objects.
How is the center of mass determined in a glass of water?
The center of mass in a glass of water can be determined by finding the balance point of the glass and water. This can be done by suspending the glass and water from a string and marking the point where the glass comes to rest. The center of mass will be located directly below this point.
Does the shape of the glass affect the center of mass?
Yes, the shape of the glass can affect the location of the center of mass. A wider and taller glass will have a lower center of mass compared to a narrow and shorter glass with the same amount of water. This is because the distribution of mass is different in each glass.
What factors can affect the center of mass in a glass of water?
The amount of water in the glass, the shape of the glass, and the material the glass is made of are all factors that can affect the center of mass in a glass of water. Additionally, any objects placed inside the glass or on top of the glass can also change the location of the center of mass.
Why is understanding the center of mass important in a glass of water?
Understanding the center of mass in a glass of water is important for maintaining balance and stability. It can also be useful in engineering and design, as the location of the center of mass can affect how an object behaves and how it can be moved or manipulated.
