Center of Mass of a jetpack-Earth System
In summary, the center of mass of an isolated system will remain in the same location regardless of internal forces, as long as there are no external forces. In a system with two bodies of different masses and no external forces, if one body moves via internal force, the other will not move in order to maintain the center of mass. In the case of an automatic jet pack on Earth, the Earth will move a very small amount as the jet pack exerts a force on it, but this does not violate Newton's First Law. The use of mass-less photons in propulsion would require the system to be analyzed in terms of momentum, but the center of mass concept would still apply.
Physics Quandary
It is known that the center of mass of an isolated system will assume the same location no matter what internal forces there are (as long as no net external force occurs).
My first question is if there exist two bodies of masses m1 and m2 in some space that has no friction, gravity, or external forces present, and one of the bodies move via some internal force (maybe a propulsion engine via fuel), will the other body move in the opposite direction to maintain the center of mass location or will it just stay there? I see two potential breaches regarding Newton’s First Law and the center of mass concept
My second question is a case of the previous question: if there is an automatic jet pack on Earth and one considers the Jetpack-Earth system (which is essentially isolated and closed), and the jet pack starts to take off from the surface of the Earth, won’t the Earth move a very, very small amount? If so, doesn’t this violate Newton’s First Law again? I know when you walk, you move the Earth a small amount to correct for the center of mass, but there is the internal force of your foot doing work on the Earth, thereby not violating Newton himself.
I am not sure if you mean an internal force as in a force between m1 and m2 which is internal to the m1 m2 system or an internal force which is internal to m1 itself.
Yes.
No. The jet pack exerts a force on the Earth so Newton’s first law doesn’t apply.
The only way to move that body via propulsion is for it to throw mass in the opposite direction. The center of mass of expelled fuel and object will remain fixed. Since the center of mass of this system doesn't move, the center of mass of the whole system doesn't move,and the other body doesn't move.
Again, the jet pack has to throw mass downwards in order to move upwards.
You can also use mass-less photons. Then the question becomes if the center of mass concept can be extended such that the rule mentioned by the OP still applies in that case.
In which case, the system would need to be analysed in terms of Momentum and everything would be OK.
The 'propellant' in both cases would be intercepted by the Earth (or at least some of it) and that would affect the overall result (no / very little net acceleration)
Sure, but the OP specifically asks about the center of mass concept.
So let's use the momentum concept and find the center of mass that way. The object will be to see whether [massless] photons enter into the computation. I am spit-balling here, never having thought much about the problem of defining the center of mass of a system containing massless components.
Start by finding a reference frame where the total momentum of the object ##m_1## plus its expelled photon plume is zero. Clearly there is such a frame. It is equally clear that it will be identical to the frame where ##m_1## started out stationary before it expelled any photons. This is the center-of-momentum frame.
[For our purposes we will be pretending that photons are classical particles (little massless bullets moving at c) and not weird quantum thingies]
Define the "center of mass" for this system. We will define it using angular momentum in the following way.
In its center of momentum frame, the system has an intrinsic angular momentum that is independent of the point we choose to use as the origin/reference point for computing angular momentum.
1. Pick a candidate center of mass. Use it as the origin of a coordinate system anchored to the center of momentum frame.
2. Perform an infinitesimal boost by ##\Delta v## in any direction.
3. If the angular momentum of the system has changed, that candidate is not the center of mass.
Repeat until you find the unique point where an infinitesimal boost in any direction results in no change to angular momentum.
Note that massless photons have linear momentum and can contribute to the angular momentum of the system.
Likes Dale
In which case, with massless photons, it's not soluble in those terms.
Related to Center of Mass of a jetpack-Earth System
1. What is the center of mass of a jetpack-Earth System?
The center of mass of a jetpack-Earth System is the point at which the mass of the entire system can be considered to be concentrated. It is the average location of all the mass in the system, taking into account the mass and position of both the jetpack and the Earth.
2. How is the center of mass of a jetpack-Earth System calculated?
The center of mass can be calculated using the formula: xcm = (m1x1 + m2x2 + ... + mnxn) / (m1 + m2 + ... + mn), where xcm is the center of mass, m1, m2, ... mn are the masses of the individual components, and x1, x2, ... xn are their respective positions.
3. Why is the center of mass important in a jetpack-Earth System?
The center of mass is important because it determines the overall motion of the system. If the center of mass is not in motion, the system as a whole will not move. It also plays a role in stability and balance of the system.
4. Can the center of mass of a jetpack-Earth System change?
Yes, the center of mass can change if the mass or position of any component in the system changes. For example, if the jetpack runs out of fuel, its mass will decrease and the center of mass will shift.
5. How does the center of mass affect the flight of a jetpack?
The center of mass affects the flight of a jetpack by determining its stability and balance. If the center of mass is too high or too low, the jetpack may become unstable and difficult to control. The location of the center of mass also affects the direction and speed of the jetpack's movement.
  • Mechanics
  • Classical Physics
