Center of Mass of open top cylinder
In summary, the cylinder has a center of mass at (h/2)*(2*pi*R*h+2*pi*R^2)-h*pi*R^2/2*pi*R*h+2*pi*R^2-pi*R^2.
naianator
48
The attached diagram shows a uniform density hollow cylindrical shell with a solid bottom and an open top. It has radius R and height h.
Find the height for the center of mass of this cylinder, taking the origin of the coordinate system at the center of the bottom. Use "pi" for π.
x_cm=m_1x_1+m_2x_2+m_3x_3/m_1+m_2+m_3
I'm not even really sure how to start but I tried this
If the top wasn't missing then the cylinder would have a center of mass at h/2 and the missing top has a center of mass at h so
CM = (h/2*(2*pi*R*h+2*pi*R^2)-h*pi*R^2)/2*pi*R*h+2*pi*R^2-pi*R^2
= pi*R*h^2/2*pi*R*h-pi*R^2
If you had just the top piece located at height h, could you determine the center of its mass?
Wouldn't it just be h?
And can you determine the mass of it?
Likes naianator
Wouldn't the masses cancel though? h = h*m/m?
You really ought to parenthesise expressions correctly. You mean
(h/2*(2*pi*R*h+2*pi*R^2)-h*pi*R^2)/(2*pi*R*h+2*pi*R^2-pi*R^2)
or in LaTex
##\frac{\frac h2(2\pi Rh+2\pi R^2)-h\pi R^2}{2\pi Rh+2\pi R^2-\pi R^2}##
But you made a mistake in simplifying to
##\frac{\pi Rh^2}{2\pi R h-\pi R^2}##
(Note that that would make it > h/2.)
or in LaTex
I'm having trouble finding where the mistake is. Is the first expression correct?
Yes, it's just the last line that's wrong. Check the signs.
Likes naianator
Ahhh yes! Thank you
Rather than that:
If both the top and bottom were missing, then the CM would be at h/2.
To this add in the bottom, which has CM at 0 .
It makes the algebra a bit easier.
Likes naianator
Related to Center of Mass of open top cylinder
1. What is the center of mass of an open top cylinder?
The center of mass of an open top cylinder is the point where the mass of the cylinder can be considered to be concentrated. It is the point at which the cylinder would balance if suspended from that point.
2. How is the center of mass of an open top cylinder calculated?
The center of mass of an open top cylinder can be calculated by finding the average position of the entire mass of the cylinder. This can be done by dividing the cylinder into smaller sections and calculating the center of mass for each section, then finding the weighted average of these positions.
3. How does the shape of an open top cylinder affect its center of mass?
The shape of an open top cylinder does not affect its center of mass as long as the mass is evenly distributed around the center axis. The center of mass will always be located at the midpoint of the height of the cylinder.
4. Does the material of an open top cylinder affect its center of mass?
The material of an open top cylinder does not affect its center of mass as long as the mass is evenly distributed. The center of mass is determined by the distribution of mass, not the material itself.
5. How is the center of mass of an open top cylinder used in real-world applications?
The center of mass of an open top cylinder is used in many real-world applications, such as designing buildings and bridges, determining the stability of structures, and calculating the trajectory of objects in motion. It is also important in fields such as physics and engineering.
