Center of mass problem involving shell
In summary, in order to find the distance the other fragment lands, you need to consider the conservation of momentum and use kinematics equations to calculate the distance traveled by the second fragment.
mmattson07
31
A shell is shot with an initial velocity 0 of 23 m/s, at an angle of θ0 = 54° with the horizontal. At the top of the trajectory, the shell explodes into two fragments of equal mass (Fig. 9-42). One fragment, whose speed immediately after the explosion is zero, falls vertically. How far from the gun does the other fragment land, assuming that the terrain is level and that air drag is negligible?
http://edugen.wiley.com/edugen/courses/crs4957/art/qb/qu/c09/fig09_46new.gif
consv momentum
M v = m1 u1 + m2 u2
Here is what I tried
Init vertical speed= 23sin54= 18.61m/s
Init horiz speed= 23cos54=13.53m/s
Time to reach top of trajectory= 18.61/9.8= 1.899s
horiz distance to top= 13.52*1.899= 25.67m
The other shell will now have the horiz speed of 23 m/s and fall for the same time it took to rise so it goes another 23*1.899=43.677m
I added both these to get 69.347m but it isn't correct
. What am I doing wrong?You have to consider the conservation of momentum. The initial momentum before the explosion is Mv. After the explosion, the final momentum is m1u1 + m2u2. Since the mass of each fragment is the same, m1 = m2. Therefore, m1u1 + m2u2 = Mv => m1(u1 - v) + m2(u2 - v) = 0 => u1 - v = -(u2 - v) => u1 = 2v - u2 From this equation, you can find the velocity of the second fragment once it leaves the explosion and then use kinematics equations to calculate the distance it travels.
Related to Center of mass problem involving shell
1. What is the center of mass problem involving a shell?
The center of mass problem involving a shell is a physics problem that involves finding the center of mass of a hollow, three-dimensional object. This is typically done by finding the average location of the mass of the object.
2. How is the center of mass of a shell calculated?
The center of mass of a shell can be calculated by dividing the object into smaller, simpler shapes and then finding the center of mass of each shape. The center of mass of the entire object is then calculated by taking the weighted average of the individual centers of mass.
3. Why is the center of mass important for shells?
The center of mass is important for shells because it allows us to understand how the object will behave when subjected to external forces. It also helps in determining the stability of the object and predicting its motion.
4. What factors can affect the center of mass of a shell?
The center of mass of a shell can be affected by several factors, including the shape and size of the shell, the distribution of mass within the shell, and any external forces acting on the shell.
5. How is the center of mass used in real-world applications?
The concept of center of mass is used in various real-world applications, such as designing stable structures, balancing objects, and understanding the movement of objects in space. It is also important in fields like engineering, architecture, and sports.
