Center of Mass Using Triple Integrals Question
In summary, for calculating the center of mass, you can use spherical or cylindrical coordinates instead of cartesian coordinates. The triple integrals in cylindrical coordinates would involve the functions being transformed into a function of the new coordinates, multiplied by the Jacobian determinant, and the change in the domain of integration.
RJLiberator
63
My question is this: When finding center of mass, can you do so using spherical/cylindrical coordinates, or must you put it in cartesian coordinates?
If you can use spherical/cylindrical coordinates, how do you set up the triple integrals ?
Thank you.
You can do it in spherical or cylindrical coordinates as well. Any triple integral in cartesian coordinates [itex]\int\int\int f(x,y,z)dxdyz[/itex] can be calculated in cylindrical coordinates(r,phi,z) as [itex]\int\int\int f(rcos\phi,rsin\phi,z)rdrd\phi dz[/itex] and in spherical coordinates as well http://en.wikipedia.org/wiki/Multiple_integral#Spherical_coordinates
You should take notice of 3 facts when changing from cartesian to another coordinate system
1) The function f to be integrated is transformed from function of x,y,z to a function of the new coordinates. For example in cylindrical coordinates from f(x,y,z) becomes [itex]f(rcos\phi,rsin\phi,z)[/itex]
2) The transformed function is mupltiplied by another function of the new coordiantes which is the the Jacobian Determinant. In cylindrical coordinates Jacobian Determinant is simply r.
3) The domain of integration changes also.
Likes RJLiberator
Hm. So I understand when calculating the center of mass it works like this:
Triple integral of x dxdydz
triple integral of y dydxdz
triple integral of z dzdydx
And then all of them over triple integral of the function (mass)
If I were to do this in cylindrical coordinates would it be the following:
triple integral of r*r drdzdtheta
triple integral of theta*r dthetadrdz
triple integral of z*r dzdthetadr
Over the mass again
Due to the added r in the cylindrical coordinates?
I am not sure what your triple integral is but for cylindrical coordinates you replace [itex]x=rcos\phi, y=rsin\phi, z=z[/itex] and you multiply by r. Also you must be carefull for the new domain of integration.
Likes RJLiberator
Yes, for sure.
My question is specifically in regards to center of mass with triple integrals.
Related to Center of Mass Using Triple Integrals Question
1. What is the center of mass using triple integrals?
The center of mass using triple integrals is a mathematical concept used to determine the average position of the mass of an object. It takes into account the mass and its distribution in three dimensions.
2. How is the center of mass calculated using triple integrals?
The center of mass is calculated by dividing the triple integral of the mass of the object by the total mass of the object. The triple integral takes into account the mass and its position in the x, y, and z directions.
3. Why is it important to know the center of mass of an object?
Knowing the center of mass of an object is important in physics and engineering because it helps determine the stability, balance, and motion of the object. It is also used in designing structures and calculating forces on objects.
4. Can the center of mass be outside of the object?
No, the center of mass cannot be outside of the object. It is always located within the boundaries of the object and represents the average position of the mass of the object.
5. How does the shape of an object affect its center of mass?
The shape of an object affects its center of mass because it determines the distribution of the mass. Objects with irregular shapes will have a different center of mass than objects with symmetrical shapes.
