Central force field derivation
In summary, the total energy of a particle can be calculated using the formula ##u^2 / 2 - k/R##. If ##u^2 \gg 2k/R##, we only use the first part of the formula, ##u^2/2##. By applying the conservation of energy law, we can use the angular momentum expression ##l = bu## to replace ##u## in the formula and obtain an expression for ##w^2 / k## using only the variables ##b, p, l##. Another helpful relationship is ##l = pw##, which can be used to solve for the problem.
lriuui0x0
101
25
A particle with unit mass has distance ##R## from the origin and initial speed ##u##. It moves in the central potential ##\Phi(r) = -k/r##. If it doesn't move in the central field, it would move in a straight line whose shortest distance from the origin is ##b## (impact parameter). When it moves in the central field, it's closest distance from origin is ##p < b## with speed ##w##. Assume ##u^2 \gg 2k/R##, find ##w^2/k## in terms of ##b, p## only.
##l = bu##
The total energy of the particle is ##u^2 / 2 - k/R##. When ##u^2 \gg 2k/R##, we take the total energy to be ##u^2/2## only. By the conservation of energy, we have:
\frac{u^2}{2} = \frac{w^2}{2} - \frac{k}{p}
Take the angular momentum expression ##l = bu##, we can replace ##u## with ##b,l## thus getting an expression for ##w^2 / k## with ##b,p,l## only. But I don't know how to get an expression with ##b, p## only.
You have used energy conservation. What else can you use?
Thanks. I solved the problem by noticing another relationship ##l = pw##.
Likes hutchphd and bob012345
Exactly, conservation of angular momentum ##l = bu = pw##.
Related to Central force field derivation
What is a central force field?
A central force field is a type of force field in which the force acting on an object is always directed towards or away from a fixed point, known as the center. This type of force field is commonly observed in systems such as planets orbiting around a star or electrons orbiting around the nucleus of an atom.
What is the importance of deriving a central force field?
Deriving a central force field is important because it allows us to understand the underlying principles and laws that govern the behavior of objects in such systems. This knowledge can then be applied to make predictions and calculations about the motion of these objects.
What are the steps involved in deriving a central force field?
The steps involved in deriving a central force field typically include identifying the forces acting on the object, determining the direction and magnitude of these forces, and using mathematical equations and principles such as Newton's laws of motion to calculate the resulting motion of the object.
What are some common examples of central force fields?
Some common examples of central force fields include gravity, electrostatic forces, and magnetic forces. These forces are all directed towards or away from a central point, such as the center of mass or the center of charge.
What are the applications of central force field derivation?
The applications of central force field derivation are vast and varied. They can be used in fields such as astronomy, physics, and engineering to understand and predict the behavior of objects in systems with central forces. This knowledge is also crucial in developing technologies such as satellites and spacecraft that rely on central force fields for their motion.
