Central Forces and Angular Momentum
In summary, if a mass is in an elliptical orbit around a central force that is inversely proportional to the distance squared, the mass will accelerate when moving closer to the focus. The angular momentum of the orbit remains constant. It is possible to show that the work done by the force is equal to the change in kinetic energy solely due to the conservation of angular momentum. There must be an additional work done in order to conserve angular momentum. The radius, velocity, and distance from the focus are all interdependent and must be chosen carefully to maintain conservation of energy and angular momentum.
azabak
32
Imagine a mass in an elliptical orbit around a central force. If such force is inversely proportional to the distance squared then the mass will accelerate when going nearer the focus. At the same time the angular momentum of the orbit is a constant.
Can one show that the work done by the force is equal to the variation of kinetic energy solely due the conservation of angular momentum?
hi azabak! :wink:
work done is always equal to the variation of kinetic energy :smile:
I'm ok with the basic concepts. My doubt is that since the distance from the focus decreases two things must happen: conservation of angular momentum and work done by the force. If you calculate just the work done due the variation of potential energy angular momentum is not conserved. For it to happen the force must do an "extra" work. In any situation of rotation conservation of angular momentum is the important factor. Therefore accepting that angular momentum is always conserved implies accepting that any central force does more work than the variation of potential energy.
Correct me if I'm wrong.
Why is that?
What do you mean?
The angular momentum of a mass m is L = m*v*R.
The central force is F = -k*m/R² where k is a constant.
The radius varies from R to r.
The work done W = -ΔU and the potential energy U = -k*m*/R.
The final kinetic energy due variation of potential energy is K = (m*v²/2)+(k*m*((1/R)-(1/r))).
To conserve the angular momentum the final kinetic energy should be K = (m*v²*R²)/(2*r²), which will be larger than the calculated just from variation of potential energy.
Therefore there must be an additional work in order to conserve angular momentum.
Careful. Angular momentum is a vector quantity:
[tex]\vec{L} = \vec{r}\times m\vec{v}[/tex]
The angle between the vectors v and r is important.
Angular momentum, properly defined as the vector product above, is conserved, but the quantity m*v*R is not.
Oh, I see. Thank you very much.
If you use the apihelion and the perihelion distance for r and R, so as to escape Doc Al's objection, you will find that you can't freely choose v, R and r. If you give the apihelion distance, and the initial speed, the perihelion distance is fixed so that both energy and angular momentum are conserved, and the 2 energies you computed are equal.
(At the perihelion and apihelion the distance vector r is perpendicular to v, so the magnitude of the angular momentum is equal to m*r*v)
So this implies that there's a unique world line such that both the variation of potential energy and angular momentum match the "required" kinetic energy.
There's always an unique wordline if you specify an initial position and velocity. If you have a central force and a conservative force field, angular momentum and total energy will be conserved.
hi azabak! :smile:
i don't understand this :confused:
potential energy is defined as minus the work done by a conservative force
angular momentum is always conserved if the force is central
(proof: d/dt(r x mr') = r x mr'' = r x F
which by definition is 0 if F is central)​
and any central force which is a sensible function of r will be the gradient of a scalar, and so will be conservative :smile:
as willem2 :smile: says …​
Hi tiny-tim.
I previously considered that the energy and angular momentum were conserved for any value of the radius. Then willem2 cleared me that it can only happen for a certain defined values of the radius. So choosing randomly any value for it would "break" both conservation of energy and angular momentum. The resultant world line is the one that both are conserved simultaneously.
hi azabak! :smile:
azabak said:
… Then willem2 cleared me that it can only happen for a certain defined values of the radius.
no he didn't, he only said that you can't choose all three of v r and R …
once you choose two of them, the third is automatically decided because energy and angular momentum are conserved
Related to Central Forces and Angular Momentum
1. What is a central force?
A central force is a type of force that acts on an object towards or away from a fixed point, known as the center of force. This force is always directed along the line connecting the object and the center of force, and its magnitude depends only on the distance between them.
2. How does a central force affect the motion of an object?
A central force causes an object to move in a curved path, either towards or away from the center of force, depending on the direction of the force. This results in a change in the object's velocity, leading to a change in its angular momentum.
3. What is angular momentum?
Angular momentum is a measure of an object's rotational motion around a fixed axis. It is defined as the product of an object's moment of inertia and its angular velocity. In simpler terms, it is the tendency of an object to continue rotating at a constant rate.
4. How is angular momentum conserved in a central force system?
In a central force system, the magnitude and direction of angular momentum remain constant as long as there is no external torque acting on the object. This is known as the law of conservation of angular momentum.
5. How do central forces relate to Kepler's laws of planetary motion?
Kepler's laws of planetary motion describe the motion of planets around the sun. The first law states that the planets move in elliptical orbits with the sun at one focus. This can be explained by the central force of gravity between the sun and the planets. The second law states that a line joining a planet and the sun sweeps out equal areas in equal time intervals, which is a consequence of the conservation of angular momentum. The third law states that the square of a planet's orbital period is proportional to the cube of its average distance from the sun, which can be derived using the law of universal gravitation and the concept of central forces.
  • Mechanics
14K
