Central Limit Theorem Question
In summary: It is a bit worse than the approximation ##A_1## for small ##x > 0##, but it is better than the approximation ##A_0## for all values of ##x > 0##.
dirtybiscuit
The Rockwell hardness of certain metal pins is known to have a mean of 50 and a standard deviation of 1.5.
a)if the distribution of all such pin hardness measurements is known to be normal, what is the probability that the average hardness for a random sample of 9 pins is at least 52.
b)what if sample is 40 pins?
So I know that μ = 50 and σ(original) = 1.5, and n = 9
σ(sample) = σ(original)/[itex]\sqrt{9}[/itex] = 1.5/3 = .5
now find P([itex]\bar{x}[/itex] > 52) by relating it to the standard normal dist
find z = (52 - 50)/.5 = 4.
This seems like a huge z score to have and it pretty much much makes the probability 0. Am I doing something wrong here? It just seems like a pointless question if in both cases the probability comes to zero.
The probabilities are really very small, but still differ from zero. There are online calculators http://www.solvemymath.com/online_math_calculator/statistics/cdf_calculator.php , for example.
ehild
Your sample size is quite small. Shouldn't you be using a t-estimator instead?
We know (or assume) that all pins follow a normal distribution. Then the mean of 9 pins follows a normal distribution as well.
The calculation is fine, the result is just a small number.
No. When the variance is known we use the normal distribution. When the variance is unknown (and is estimated using the data itself) we use the t-distribution.
The probability is small, but nowhere near zero. (In fact, the ability to estimate very small probabilities is crucial in reliability and safety studies, etc.) For large ##x > 0## you can find simple, fairly accurate approximations to ##G(x) \equiv P(X > x)## for standard normal ##X##.
Let [tex]\phi(t) = \frac{1}{\sqrt{2 \pi}} e^{-t^2/2}. [/tex]
We have
[tex] G(x) = \int_x^{\infty} \phi(t) \, dt \\
A_1(x) = \frac{\phi(x)}{x} \;\; \text{approximation 1}\\
A_2(x) = \frac{\phi(x)}{x} - \frac{\phi(x)}{x^3} \;\; \text{approximation 2} [/tex]
The functions ##A_1(x)## and ##A_2(x)## are approximations to ##G(x)##, with ##A_2## being a bit better than ##A_1## for large ##x > 0## (but may be worse for small ##x > 0##). You can see how they perform from the following table:
Code:
  x       G(x)      A1(x)      A2(x)
 1.0  1.58655e-01 2.41971e-01 0.00000e+00
 1.5  6.68072e-02 8.63451e-02 4.79695e-02
 2.0  2.27501e-02 2.69955e-02 2.02466e-02
 2.5  6.20967e-03 7.01132e-03 5.88951e-03
 3.0  1.34990e-03 1.47728e-03 1.31314e-03
 3.5  2.32629e-04 2.49338e-04 2.28984e-04
 4.0  3.16712e-05 3.34576e-05 3.13665e-05
These approximations are based in integration by parts, using the fact that ##d \phi(t)/dt = - t \phi(t)##:
[tex] G(x) = \int_x^{\infty} \phi(t) \, dt = \int_x^{\infty} \frac{1}{t} \left(- \frac{d \phi(t)}{dt} \right) \, dt
= \frac{\phi(x)}{x} - \int_x^{\infty} \frac{\phi(t)}{t^2} \, dt[/tex]
The approximation ##A_1(x)## is just the first term above, and it should be a pretty good approximation for large ##x > 0## because the magnitude of the neglected term is less than ##G(x)/x^2##. The approximation ##A_2(x)## estimates the second term above through another integration by parts.
Related to Central Limit Theorem Question
1. What is the Central Limit Theorem?
The Central Limit Theorem is a statistical principle that states that as the sample size of a population increases, the sampling distribution of the mean will approach a normal distribution, regardless of the shape of the original population distribution.
2. Why is the Central Limit Theorem important?
The Central Limit Theorem is important because it allows us to make inferences about a population based on a sample, by using the properties of the normal distribution. This is useful in many fields, such as economics, psychology, and biology.
3. Does the Central Limit Theorem apply to all types of data?
The Central Limit Theorem is most commonly applied to data that follows a normal distribution, but it can also be applied to non-normally distributed data as long as the sample size is large enough (usually at least 30). However, there are certain cases where the Central Limit Theorem may not apply, such as when the population is very skewed or has extreme outliers.
4. How is the Central Limit Theorem used in practice?
In practice, the Central Limit Theorem is used to estimate population parameters, such as the mean or standard deviation, by taking a sample from the population. It is also used in hypothesis testing to determine the likelihood of obtaining a certain sample mean.
5. Are there any limitations to the Central Limit Theorem?
While the Central Limit Theorem is a powerful tool, it does have some limitations. As mentioned earlier, it may not apply to all types of data, and it also assumes that the samples are independent and identically distributed. Additionally, the approximation of a normal distribution may not be accurate for smaller sample sizes.
  • General Math
  • Linear and Abstract Algebra
