Centre of mass and moment of mass
In summary, the moment of mass of a system of particles is the sum of each particle's mass multiplied by its distance from an arbitrary reference point. It is calculated with respect to the center of mass, which is the location where the moment must be a single number.
jishitha
23
What is moment of mass of system of particles? And how it relates centre of mass...?
The moment of mass of a system of particles is defined in the link below:
http://en.wikipedia.org/wiki/Center_of_mass
The moment of mass of a system of particles is equal to the sum of the product of each particle's mass and its distance from an arbitrary reference. At the location of the center of mass, the moment must necessarily be a single number. What is it?
FAQ: Centre of mass and moment of mass
What is the centre of mass?
The centre of mass is a point in an object or system where the entire mass can be concentrated. It is the point at which the object is perfectly balanced, and all the external forces acting on it can be thought of as acting through this point.
How is the centre of mass different from the centre of gravity?
The centre of mass and centre of gravity are often used interchangeably, but there is a slight difference. The centre of mass is the point where the entire mass of an object is concentrated, while the centre of gravity is the point where the entire weight of an object is concentrated. This distinction only becomes significant in cases where the gravitational field is not uniform.
What factors affect the location of the centre of mass?
The location of the centre of mass depends on the distribution of mass within an object or system. It can be affected by the shape, size, and density of the object, as well as any external forces acting on it. For example, changing the shape of an object can shift its centre of mass.
What is the moment of mass?
The moment of mass is a measure of the rotational force of an object or system. It is calculated by multiplying the mass of the object by its distance from a specified axis of rotation. The unit of measurement for moment of mass is kilogram-meters squared (kg*m^2).
How is the centre of mass and moment of mass used in practical applications?
The centre of mass and moment of mass are important concepts in fields such as physics, engineering, and biomechanics. They are used to analyze the stability and balance of objects and systems, and to design structures that can withstand external forces. In sports, understanding the centre of mass and moment of mass is crucial for optimizing performance and preventing injury.
