Centre of mass of a solid hemisphere.
To find the center of mass (CoM) of a uniform solid hemisphere of radius r, it is suggested to model the hemisphere as a series of thin discs stacked vertically. The equation for CoM can be modified to R = (1/M)∫ρy dV, where dV is the volume of each disc approximated as area times height. A recommendation is made to use a different variable for integration, such as y, to avoid confusion. The volume element dV can be expressed as the area of the disc times dy, leading to the integral R = (πρ/M)∫y^3 dy. This approach successfully leads to the conclusion that the CoM lies at a distance of (3/8)r from the center of the flat face.
grahammtb
Hi there, I can't get my head round how to do the math for this problem. I'm sure it's not as hard as I think...
Show that the CoM of a uniform solid hemisphere of radius r lies at a distance (3/8)r from the centre of the flat face.
You may find it convenient to regard the hemisphere as consisting of a very large number of extremely thin discs of varying radii stacked on top of each other.
I'm thinking I'll need the equation for CoM, involving an integral: R=(1/M)\intrdm. This I think can be modified to: R=(1/M)\intr\rhodV, where rho is the density at radius r.
N/A
Thanks very much for any help!
~Graham :wink:
So far, so good. To avoid confusion, I recommend you use a different variable of integration than r--let's say y. (Imagine the hemisphere axis to be along the y-axis from y = 0 to y = r.) What's the volume of a thin disk located at position y?
Ok, since the discs are extremely thin, I'd approximate the volume of the disc to be its area. So: A(y) = Pi.(r(y))2.
Hi Graham! :smile:
grahammtb said:
… You may find it convenient to regard the hemisphere as consisting of a very large number of extremely thin discs of varying radii stacked on top of each other.
… dV …
You're ignoring the hint …
if you use discs stacked on top of each other (with height z, say), you can go straight to integrating over dz, instead of dV. :wink:
The disks are thin, but not zero thickness! :bugeye: Hint: dV = Area dy.
Ah I think I see...so if dV = Ady, then I can put that into my original eqn. for CoM? R = (1/M)\int\rhoydV. Then R = (Pi.\rho/M)\inty3dy...I think :redface:
You're on the right track, but not quite there yet. What's the radius of a disk at position y? (Draw yourself a diagram.)
yep! It worked! Thanks a lot guys, I'd have spent all afternoon trying to pick my way through :)
  • · Replies 19 ·
  • · Replies 18 ·
