Centrifugal (Ficticious) Force problem
We are given the speed v = \frac{2\pi r}{T} = \frac{2\pi \times 8}{4.5} = \frac{16\pi}{4.5} = \frac{32}{9}\piIn summary, in an amusement park ride called the Roundup, passengers stand inside a 16m diameter rotating ring. The ring rotates once every 4.5 s and tilts into a vertical plane. The force exerted on a rider with a mass of 55kg at the top of the ride is equal to their weight plus the push force, which is directed towards the center of the ring. The longest rotation period of the wheel that will prevent riders from
mst3kjunkie
47. In an amusement park ride called the Roundup, passengers stand inside a 16m diameter rotating ring. After the ring has acquired suficient speed, it tilts into a vertical plane.
a. suppose the ring rotates once every 4.5 s. If a rider's mass is 55kg, with how much force does the ring pus on her at the top of the ride? At the bottom?
b. What is the longest rotation period of the wheel that will prevent the riders from falling off at the time?
I've calculated that the radius is 8m and the period T is equal to (1/4.5) or .22 revolutions per second. I'm completely stuck as to where to go from here. help?
[tex] F = ma = m\frac{v^{2}}{r} [/tex]
At the top of the ride both the weight, [itex]W[/itex], and the "push force" [itex]F_P[/itex] on a passenger is directed towards the center of the ring. The combined effect of these two forces gives us the needed centripetal force [itex]F_C[/itex] to make the passenger go along with the ride so
[tex]F_P + W = F_C[/tex]
FAQ: Centrifugal (Ficticious) Force problem
What is the Centrifugal Force problem?
The Centrifugal Force problem is a fictitious force that appears to act on objects in a rotating frame of reference. It is caused by the tendency of objects to continue moving in a straight line even when the frame of reference is rotating.
How does the Centrifugal Force problem affect objects?
The Centrifugal Force problem does not actually affect objects, but rather it is an apparent force that arises due to the frame of reference. This means that objects in a rotating frame of reference may appear to be experiencing a force, but in reality they are simply following a straight path.
Can the Centrifugal Force problem be measured?
No, the Centrifugal Force problem cannot be measured because it is not a real force. It is only an apparent force that arises due to the frame of reference. However, the effects of this apparent force can be observed, such as the feeling of being pushed outwards when riding on a spinning amusement park ride.
How is the Centrifugal Force problem related to the Coriolis effect?
The Centrifugal Force problem and the Coriolis effect are both apparent forces that arise due to the rotation of a frame of reference. The Centrifugal Force problem is caused by the tendency of objects to continue moving in a straight line, while the Coriolis effect is caused by the rotation of the Earth. Both of these effects are important to consider in certain situations, such as navigation and weather patterns.
Can the Centrifugal Force problem be eliminated?
Since the Centrifugal Force problem is only an apparent force, it cannot be eliminated. However, it can be corrected for by using the laws of physics and understanding the effects of the rotating frame of reference. This is important in areas such as engineering and navigation, where the effects of the rotating frame of reference must be considered for accurate calculations and predictions.
18K
