Centrifugal pump cavitation prevention
In summary: I see where you came up with 108 ft. Look at the right side of the graph. It says NPSH and gives a separate scale that reads NPSH feet.
gfd43tg
50
The 9.75 in. impeller option of the Taco Model 4013 F1 series centrifugal pump (pump curve given by Figure P3-2) is used to pump 200 GPM of water at 25 C from an open reservoir whose surface is above the centerline
of the pump inlet (Figure P3-1). The piping system from the reservoir to the pump consists of 10.0
ft of cast iron pipe with an ID of 2.0 in. and an average roughness of 0.02 in. There are several
minor losses: a sharp-edge inlet (Kc = 0.5), three flanged smooth 90 degree elbows (Ke = 0.3 each)
and a fully open flanged globe valve (Kv = 6.0).
Estimate the minimum elevation of the liquid surface above the pump inlet required to operate the pump without cavitation.
Hint: Recall that the NPSH is the difference between the head at the pump inlet and the vapor
pressure head (Equation 1).
Data: Vapor pressure of water at 25 C = 3.169 kPa
Density of water = 997.0 kg /m3
Viscosity of water = 8.91 X 10-4 km / m s
Patm = 101.3 kPa
I keep getting a pressure that is negative. using the chart that I attached for the Taco Pump, I get a NPSH of about 1.12 m (3.7 feet) and when I use equation one, the pressure at the inlet of the pump is negative.
  • 3.3.pdf
  • 3.3 attempt 1.pdf
From the graph, what is the minimum NPSH required to avoid cavitation? For 200 gpm, what is V2/2g coming into the pump? What does P/ρg have to be at the pump inlet to aviod cavitation?
From looking at the graph, I see the NPSH head is about 4 feet, just slightly under. In my attempt, I just divided Q/A to get V, and the only unknown is P. When I calculated it, I got -5.05 kPa, which doesn't make sense to me.
I see that there is an NPSH-available and NPSH-required. The equation given is for the available NPSH according to wikipedia
http://en.wikipedia.org/wiki/NPSH#NPSH_in_a_Pump
And the graph labels ''required NPSH''. To prevent cavitation, does the available NPSH = required NPSH?
Yes. That's my understanding. 108 ft.
Chet
Ah, yes. I missed that. Thanks.
It looks like you used P2=1 atm in the calculations when you should have been using the pressure at the entrance to the pump. You first need to determine what the pressure at the entrance to the pump has to be so that you match the NPSH. You then have to determine what the height of the water in the reservoir has to be to give you that pressure at the entrance to the pump.
Chet
I think you have misread. My P2 = -5.05 kPa, not 1 atm. That is what I calculate the pressure at the entrance of the pump to be. Just look at the last line and you will see that I am solving for P2 using the equation given to us for NPSH. My whole problem is that when I use that formula, I get a negative pressure for P2.
I know once I get P2, all I have to do is use bernoulli to get the height difference.
I see what you are saying now. The NPSH concept seems a little confusing. It looks like, to calculate the NPSH, one is comparing the stagnation pressure within the entry pipe with the vapor pressure of the water. Apparently what happens is that the cross sectional area inside the pump is much higher than in the entry pipe, so the fluid velocity within the pump is much smaller than in the entry pipe. Therefore, inside the pump, the pressure starts out as being roughly equal to the stagnation pressure prior to the pump. This is what is compared to the vapor pressure to guarantee (by the pump manufacturer) that there is no cavitation inside the pump. However, in your problem, what the calculation seems to be indicating is that there may be cavitation in the pipe leading up to the pump. I don't know whether this matters or not. Still I would not allow P2 to come out this low. If I were designing the system, I would choose P2 no lower than the vapor pressure.
Chet
The professor is here and we came to the conclusion that the problem is messed up, because the velocity head is overcoming the vapor pressure, which accounts for the negative pressure calculation.
Related to Centrifugal pump cavitation prevention
1. What is centrifugal pump cavitation?
Centrifugal pump cavitation is the formation of vapor bubbles within the pump due to low pressure regions. These bubbles can collapse, causing damage to the pump and reducing its efficiency.
2. What are the common causes of centrifugal pump cavitation?
The most common causes of centrifugal pump cavitation include high pump speeds, high suction lift, and clogged or damaged impellers. It can also be caused by a mismatch between the pump and system operating conditions.
3. How does cavitation affect pump performance?
Cavitation can significantly decrease the efficiency and output of a pump. It can also cause noise and vibration, leading to potential damage and premature failure of the pump.
4. What are some methods for preventing centrifugal pump cavitation?
Some methods for preventing cavitation include properly sizing the pump for the system, reducing the pump speed, and installing a suction stabilizer or inducer. Regular maintenance and inspection of the pump are also crucial for preventing cavitation.
5. How can I tell if my pump is experiencing cavitation?
Some signs of pump cavitation include unusual noise or vibration, decreased flow or pressure, and damage to the impeller or other pump components. A visual inspection of the pump can also reveal signs of cavitation, such as pitting or erosion on the impeller.
  • Mechanical Engineering
