Centrifuge - find centripetal acceleration
In summary, the conversation discusses the design of a centrifuge with a spin rate of 15,300 rev/min. The maximum centripetal acceleration for a test-tube sample held 14.7 cm from the rotation axis is calculated to be 377361.36 m/s2. The formula for tangential acceleration is discussed, with the correct formula being a[SUB]t= (v[SUB]final - v[SUB]initial)/t[SUB]final-t[SUB]initial. The tangential acceleration for the centrifuge while spinning up is calculated to be 3.099 m/s2.
dragonladies1
23
You are designing a centrifuge to spin at a rate of 15,300 rev/min.
(a) Calculate the maximum centripetal acceleration that a test-tube sample held in the centrifuge arm 14.7 cm from the rotation axis must withstand.
377361.36 m/s2
(b) It takes 1 min, 16 s for the centrifuge to spin up to its maximum rate of revolution from rest. Calculate the magnitude of the tangential acceleration of the centrifuge while it is spinning up, assuming that the tangential acceleration is constant.
Is the correct equation for the tangential acceleration at[SUB=r*a?
If not, what is the correct formula(s)?
[h2]The Attempt at a Solution[/h2]
at=.147*377361.36=55472.12 m/s2
I get the 377361.36 m/s2 answer. You are supposed to show how you got yours so we can find out where you went wrong . . .
I started with v = 2πrn/T where n is the number of turns and T the time taken.
Then the standard formula for centripetal acceleration can be used to finish it.
[/QUOTE]
No.
The tangential acceleration is the derivative with respect to time of the tangential
speed. It's also the component of acceleleration in a direction perpendicular to the radius.
For a constant angular acceleration, the acceleration is equal to
[tex] \frac { v_{final} - v_{initial} } { t_{final} - t_{initial} } [/tex]
Just like linear acceleration.
Thank you. So let me make sure I got this correctly...for my problem:
Vfinal=(2*pi*.147)/(1/255)=235.53 m/s
Vinitial= 0
Tfinal=76 seconds
Tinitial=0
So...
235.53/76=3.099 m/s2
Is this correct?
Thank you very very much. I got the answer.
FAQ: Centrifuge - find centripetal acceleration
What is a centrifuge and how does it work?
A centrifuge is a laboratory instrument used to separate substances based on their density. It works by spinning samples at high speeds, causing the denser substances to move to the bottom of the tube and the less dense substances to remain at the top.
What is centripetal acceleration and how is it related to centrifugation?
Centripetal acceleration is the acceleration towards the center of a circular path. In the context of centrifugation, it is the force that causes the denser substances to move towards the bottom of the tube. Centrifugal force, on the other hand, is the apparent outward force that results from the rotation of the centrifuge.
How is centripetal acceleration calculated in a centrifuge?
Centripetal acceleration can be calculated using the formula a = v^2/r, where a is the acceleration, v is the velocity of the sample, and r is the radius of the centrifuge. In a centrifuge, the velocity of the sample is directly proportional to the speed at which the centrifuge is spinning.
What are the factors that affect centripetal acceleration in a centrifuge?
The factors that affect centripetal acceleration in a centrifuge include the speed of rotation, the radius of the centrifuge, and the density of the substances being separated. The higher the speed and the larger the radius, the greater the centripetal acceleration. The denser the substances, the greater the centripetal acceleration required to separate them.
What are some common uses of centrifugation in scientific research?
Centrifugation is commonly used in scientific research to separate substances such as blood components, proteins, and DNA. It is also used in the purification and isolation of viruses and bacteria, as well as in determining the sedimentation rate of particles in a sample. It is an essential technique in fields such as biology, chemistry, and medicine.
