Centripal Force - Friction needed to keep a car tracking a curve
In summary: If the car is traveling at a constant speed (50.0hm/hr or 13.9m/s), then the centripetal acceleration is also constant. So, you can use the equation for centripetal acceleration to find the minimal value for the coefficient of friction. The coefficient of friction is the ratio of the force needed to keep the car on the curve (centripetal force) to the force of friction. In this case, the minimal value for the coefficient of friction is .03.
Julian3
The question is- What is the minimum coefficient of static friction that would keep the car from sliding off the curve? The Cars mass is 13500KG and it is traveling at 50.0hm/hr(13.9m/s) and the curve has a radius of 2.00 x102 m. I know the centripetal acceleration of the car is .97m/s and the centripetal force is 3381.2N. FF=FN(coefficient of friction)
I know you have to draw a free body diagram, which I think it would be Force Friction pointing down as well as Force weight and Force Normal pointing up and Force Velocity to the right. I know you have to make it into a equation to solve for the Coefficient of Friction.
Im basically stuck at this part because I don't know what the force would have to be to keep the car on the curve, and i don't know how to set up the equation, sorry for not having an attempt at solving it but I am really confused by what we are currently covering in class.
Well, no. The forces from the road on to the car: Force Normal pointing up and Force Friction pointing towards the curve center.
The forces from the car on the road: Force Normal pointing down and Force Velocity pointing away from the curve center.
In addition: Force Frictionk(Force Normal), where k is the coefficient of static friction.
Is Force Normal the centripetal force on the car and if so how do you get force friction?
Force Normal is the force from the car normal to the road surface. Call it the weight of the car. In your terms, Force Velocity is the centripetal force.
That doesn't seem any more accurate than the original statements.
Both of those forces are at an angle, the normal force being normal to the road surface (so up and towards the curve centre), while force of friction is parallel to the road surface. In principle, both acting up the slope and acting down the slope should be considered. (On a steeply banked road there may be a minimum speed.)
This is the 'centrifugal force' view, i.e. using non-inertial frames. It's valid, if you know what you are doing. I find it less confusing to stick with inertial frames. In that view, centripetal force is the required resultant force (not an applied force) to keep the car going around the curve.
I would recommend not calling it the weight, though maybe that's reasonable in the non-inertial frame.
Well, without any force from the road on to the car (think slippery ice), the car is unable to turn and will continue straight ahead. So, whatever you call it, some force from the road is necessary for the car to turn.
There's no mentioned of a banked road, so I would assume it's a flat road. You already know the centripetal acceleration, and you assume some constant for g, the acceleration related to gravity when in free fall. The centripetal force is mass x centripetal acceleration, and the vertical force is mass x g . How can you use this information to determine the minimal value for the coefficient of friction?
Related to Centripal Force - Friction needed to keep a car tracking a curve
1. What is centripetal force?
Centripetal force is the force that keeps an object moving in a circular path. It acts towards the center of the circle and is necessary to maintain the object's speed and direction of motion.
2. How does centripetal force relate to friction in a car?
In order for a car to track a curve, the centripetal force must be provided by the friction between the car's tires and the road. Without enough friction, the car would slide off the curve due to its inertia.
3. How is the amount of friction needed to keep a car tracking a curve determined?
The amount of friction needed depends on the speed of the car, the tightness of the curve, and the weight of the car. The faster the car is going or the tighter the curve, the more friction is needed to keep the car on track.
4. Can other factors affect the amount of friction needed for a car to track a curve?
Yes, other factors such as the condition of the road surface, the type of tires on the car, and the weather conditions can also affect the amount of friction needed for a car to track a curve. For example, wet or icy roads can decrease the amount of friction available, making it more difficult for the car to maintain its course.
5. How can a driver adjust the amount of friction needed for a car to track a curve?
A driver can adjust the amount of friction by adjusting the speed of the car. Slowing down can decrease the amount of friction needed, while increasing speed will require more friction. Properly inflated tires and choosing the appropriate tires for the road conditions can also help maintain the necessary amount of friction for safe and smooth turning.
