Centripetal acceleration at equator
In summary, the centripetal acceleration for a person standing at the equator is approximately 0.03 m s–2, which is determined by the force R and indicates the apparent strength of the gravitational field. This value differs by about 0.3% from the acceleration at the poles, which can be calculated using the formula GM/r^2 and varies with local rock types. The average acceleration due to gravity for the whole planet is 9.81 m/s^2, but it is slightly higher at the poles (9.83 m/s^2) and slightly lower at the equator (9.79 m/s^2).
Masafi
65
The centripetal acceleration of a person standing at the equator is about 0.03 m s–2.
(Radius of the Earth = 6.4 × 106 m.)
The size of the force R provides a measure of the apparent strength of the gravitational field. Show that the apparent field strength g at the equator differs from that at the poles by about 0.3%.
The answer is:
(0.034 ÷ 9.81) × 100% = 0.35%
I don't understand this. How do we know that the acc at the pole is 9.81, and that 0.034 is the difference in the 2 accerelations?
The acceleration due to gravity 'g' you can measure.
You can also work it out from GM/r^2 ( M is the mass of the Earth and r is the radius)
ps. 9.81m/s^2 - is an average for the whole planet,
g is around 9.79 m/s^2 at the equator and 9.83 m/s^2 at the poles - it also varies with local rock types
The acceleration due to gravity, denoted by "g", is a constant value of 9.81 m/s^2 at the Earth's surface. This is the value used in the formula to calculate the apparent field strength at the equator (0.034 m/s^2). The 0.034 m/s^2 is the difference between the centripetal acceleration at the equator (0.03 m/s^2) and the acceleration due to gravity (9.81 m/s^2).
To calculate the percentage difference, we take the difference between the two values (9.81 - 0.03 = 9.78 m/s^2) and divide it by the original value (9.81 m/s^2), then multiply by 100 to get a percentage. This calculation results in a 0.35% difference between the apparent field strength at the equator and the poles. This shows that there is a slight variation in the gravitational field strength at different points on the Earth's surface due to the Earth's rotation.
Related to Centripetal acceleration at equator
1. What is centripetal acceleration at the equator?
Centripetal acceleration is the acceleration that an object experiences when it moves in a circular path. At the equator, this acceleration is caused by the rotation of the Earth.
2. How is centripetal acceleration calculated at the equator?
The formula for centripetal acceleration at the equator is a = v^2 / r, where v is the velocity of the object and r is the radius of the Earth at the equator.
3. What is the value of centripetal acceleration at the equator?
The value of centripetal acceleration at the equator is approximately 0.034 meters per second squared (m/s^2). This value varies slightly depending on the exact location on the equator.
4. How does centripetal acceleration at the equator affect objects on Earth?
The centripetal acceleration at the equator has a small but measurable effect on the weight of objects on Earth. Since the acceleration is directed towards the center of the Earth, objects at the equator experience a slightly lower gravitational force compared to objects at the poles.
5. Does centripetal acceleration at the equator have any impact on the Earth's rotation?
Yes, the centripetal acceleration at the equator plays a crucial role in maintaining the Earth's rotation. Without this acceleration, the Earth's rotation would slow down and eventually stop.
