Centripetal force and orbital motion....
In summary, the conversation discusses the relationship between the force of gravity and centripetal force in various types of curved motion. It is determined that the centripetal force is always present in any curved path, and its magnitude depends on the radius of curvature. In motion along a parabolic path, the centripetal force is less than the force due to gravity, while in circular or elliptical motion, the comparison cannot be made. In planetary motion with a single center of force, the normal component of acceleration is exactly equal to gravity in circular motion and smaller than gravity in elliptical motion.
ViolentCorpse
190
Hi,
The force of gravity is the centripetal force when an object is in motion. But in projectile motion, where the speed is not enough to keep it in orbit, could the force of gravity be equated to centripetal force?
I'm trying to understand if all types of curved motion can be explained by centripetal force, or put differently, instances where the concept of centripetal force applies. For example, if a projectile is allowed to fall right through Earth matter (instead of colliding with the ground (in our imagination, of course)), would it be able to orbit it in some kind of weird curve? Would the centripetal force apply here? If it can, then it must have to be different than the force of gravity, which is strange because centripetal force is always just a manifestation of some other force and the only force involved in projectile/satellite motion is gravity..
I hope you guys are getting my point..
Centripetal forces exist on any curved path, not just a circular path. For parabolic motion under gravity only, the centripetal force at any point is the component of the gravity force perpendicular to the tangent of the path at that point
Likes ViolentCorpse
Interesting!
There is, however, a radius term in the formula of centripetal force. What could be the radius of a parabola?
ViolentCorpse said:
Interesting!
In motion along any plane curve, there are two components of acceleration, tangential and normal. The tangential component is equal to dv/dt, where v is the speed. The normal component is equal to v^2/r where v is the speed and r is the radius of curvature. This is correct for any curve, parabolic, circular, or arbitrary.
Likes ViolentCorpse
Makes perfect sense! Thanks so much! :)
There's just one more thing I must ask: Is the centripetal force less than the force due to gravity when the curve of a projectile is parabolic, equal to gravity when it is circular and greater than gravity when it is elliptic?
1. Projectile motion with only gravity: The two components, tangential and normal, must together add as vectors to give the downward acceleration due to gravity, so the normal (centripetal) component will be numerically less than g.
2. Circular or elliptical motion: If we are still talking about motion on the earth, I don't see gravity alone being responsible for either circular or elliptical motion, so the comparison cannot be made.
3. Planetary motion with a single center of force: If the motion is circular, then it is also with constant speed, so there is no tangential component of acceleration, and the normal component is exactly equal to gravity. If the motion is elliptical, the gravitational force contributes to the normal component and the tangential component, so the normal component will be numerically smaller than the gravitational force/mass.
Likes ViolentCorpse
Thank you so much! :)
Related to Centripetal force and orbital motion....
What is centripetal force?
Centripetal force is a force that acts towards the center of a circular path, keeping an object moving along that path. It is necessary for an object to maintain circular motion.
What is orbital motion?
Orbital motion is the motion of an object around a larger object, such as a planet around a sun. It is governed by the force of gravity and follows a curved path.
What is the relationship between centripetal force and orbital motion?
The centripetal force required for an object to maintain orbital motion is provided by the force of gravity between the two objects. The centripetal force keeps the object in a circular orbit around the larger object.
What factors affect the strength of centripetal force in an orbit?
The strength of centripetal force in an orbit is affected by the mass of the objects involved, the distance between them, and the velocity of the orbiting object. A larger mass or shorter distance will result in a stronger centripetal force, while a higher velocity will require a stronger force to maintain the orbit.
How is centripetal force related to the speed of an object in orbit?
The centripetal force required for an object to maintain an orbit is directly proportional to the square of the speed of the orbiting object. This means that as the speed increases, the centripetal force required also increases. If the speed is doubled, the centripetal force required increases by a factor of four.
