Centripetal force and water in a Bucket
In summary: C Advanced Mechanics and Thermodynamics, by Neil Ashcroft, page 166.In summary, the author is explaining why water falls out of a bucket when it is not being swung fast enough. If the bucket is swung at a faster centripetal acceleration, then gravity will take over and the water will fall out of the bucket.
Jimmy87
686
To explain why water falls out of a bucket when it is not being swung fast enough
a = mv^2/r
I have had a look on previous threads and nearly get it but still a bit confused. When the bucket is upside down and the required centripetal force is 9.81m/s^2 then the water will stay in the bucket and the tension in the string will be zero and the normal force from the bottom of the bucket on the water will also be zero. If the bucket was swung where the required centripetal acceleration was 5m/s^2 then gravity would provide too much and the water would fall out of the bucket. It's the description in my book that confuses me:
"In order for the water to stay in the bucket when it is upside down the water needs to be accelerated (pulled downwards) faster than what gravity would move the water". If water is being pulled downwards faster than gravity then wouldn't it fall out the bucket even faster not stay in the bucket? Also if the required centripetal acceleration is 5m/s^2 then surely the bucket would also fall so since they are both falling wouldn't the water still stay in the bucket until it hit the ground?
Any help is much appreciated!
Can't make much of what this is trying to say. Anyway, there is no other downward pulling force.
Good point. And you are correct. So you don't just get the water on your head, but the bucket as well!
Likes 1 person
Thanks. So if the bucket was being swung at 5m/s^2 then would the water and bucket fall at the same rate (i.e. the water would stay in the bucket the whole time until it fell on your head)?
At ##\omega^2 r = 5## m/s2, gravity would win at an angle of 30 degrees above horizontal. The water pours out, rope goes slack, etc. No uniform circular motion possible (which, by the way is generally the case: g pulls down both at the bottom and at the top).
Wait for reasonable weather and do the experiment! Tip: use a small bucket.
a = mv^2/r
You should give us the name of the physics text you are using and the page that this explanation appears on. Incorrect solutions in texts are not uncommon but they are often minor mistakes such as calculation errors. This is a conceptual error that indicates that the author has a fundamental misunderstanding of something rather basic. I would complain to your teacher.
AM
Related to Centripetal force and water in a Bucket
1. What is centripetal force?
Centripetal force is the inward force that keeps an object moving in a circular path. It is always directed towards the center of the circle and is responsible for keeping the object from flying off in a straight line.
2. How is centripetal force related to water in a bucket?
In the case of water in a bucket, the centripetal force is provided by the bottom of the bucket. As the bucket is swung in a circular motion, the water is forced to move in a circular path due to the centripetal force acting on it.
3. What happens to the water in a bucket when the centripetal force is increased?
When the centripetal force is increased, the water in the bucket will move faster in a circular path. This is because the centripetal force is directly proportional to the speed of the object moving in a circular path.
4. Can centripetal force be greater than the weight of the object?
Yes, centripetal force can be greater than the weight of the object. In the case of water in a bucket, the centripetal force provided by the bucket's bottom can be greater than the weight of the water, which allows the water to stay in the bucket even when it is upside down.
5. What is the relationship between centripetal force and the radius of the circular path?
The centripetal force is inversely proportional to the radius of the circular path. This means that as the radius increases, the centripetal force decreases and vice versa. This relationship can be seen in the formula for centripetal force, F = mv²/r, where r is the radius of the circular path.
