Centripetal Force Banked Curves
In summary, the author is trying to understand why force parallel is omitted from the FBD when dealing with a vehicle traveling around a banked curve. They believe that force parallel should be included due to the fact that gravity is still acting on the vehicle. They provide an example of how force parallel would be included in a standard incline plane problem.
nick76342
This is a conceptual issue which I am trying to understand:
When you are describing a vehicle traveling on a banked curve, force parallel (the force which is found to be parallel to the surface of the road pointing down the bank) is omitted from the FBD and the equations that follow. Yet, force perpendicular still exists. I am not sure why force parallel is omitted since gravity is still acting on the car and should apply some force pulling the car down the hill. I can see where the velocity of the vehicle as it travels along the curve would counter this force, yet I do not understand why force parallel would not be included. In a standard incline plane problem, force parallel dictates an object's motion down the incline. Shouldn't the same apply to a banked curve regardless of the speed of the car, or whether friction is acting on the car?\
Any help would be much appreciated.
a = v^2 /r
Perhaps force parallel is somehow already included in the centripetal force?
Hello Nick, :welcome:
Is it really? Or is it for a specific case ? Do you have an example ?
One example would be:
For a car traveling with speed v around a curve of radius r, determine a formula for the angle at which a road should be banked so that no friction is required.
In this case we are looking to derive the design angle. But how do we account for force parallel. Or is force parallel under the name of the x component of Fn?
No friction means net force is centripetal force. Gravity and normal force are the only ones that appear in FBD and they add up to centripetal. No need for a parallel component from friction for that particular combination of speed/radius/banking angle
The only applied force that is purely in the downslope direction would be friction, but there is no friction in this scenario. Since we do not need to find the normal force, I would expect forces in the downslope direction to be considered, and (in the lab frame) these to consist only of the downslope component of gravity. This would equate to the downslope component of the centripetal force.
(In the car's frame, there wouid be the downslope component of centrifugal force, with a net force of zero.)
I am looking for where gravity is pulling the car down the bank (not that the car is moving down the bank or not). So does that mean that the x component of the normal force is really what I am looking for?
So the down slope component is simply a component of the centripetal acceleration?
The downslope component of the acceleration is simply a component of the centripetal acceleration; the force that produces it is (in this instance) just the downslope component of gravity.
But I am still unclear about the method you refer to in your original post. Please post the whole method.
I think I understand this all now. Thank you everyone!
Could you be clear and complete instead of bringing in pieces of inconsistent problems/examples ?
For the purposes of clarification:
I did not initially give an example since the question I had did not pertain to the root of any question I had been given in particular, but was my own question in drawing FBDs and wondering where the force parallel had gone which I remembered from working with incline planes. After doing some more problems in addition to your input, I now have a better perception of the relationships of these forces. I cannot further elaborate on any particular question since no question asked for this, just my own curiosity of how forces interact in these types of situations. Sorry for the confusion.
OK. Thing to remember is normal force is always perpendicular to the surface and gravity is always down :smile:
Friction is sideways and opposes motion, so it can be either direction (up or down) parallel to slope.
In case its not obvious from earlier replies... You can't always ignore forces parallel with the slope.
Typically a banked curve is designed for one particular speed. At that speed no friction up or down the bank is required. However at other speeds friction is required.
A problem might state the bend is designed for 60mph and ask you to calculate the minimum speed below which you slide down, and the Max speed above which you slide up the bank.
Related to Centripetal Force Banked Curves
1. What is centripetal force?
Centripetal force is the force that acts on an object moving in a circular path, pulling it towards the center of the circle.
2. How is centripetal force related to banked curves?
In banked curves, the centripetal force acts perpendicular to the surface of the road, providing the necessary force to keep the vehicle moving in a circular path.
3. What factors affect the amount of centripetal force needed for a banked curve?
The speed of the vehicle, the mass of the vehicle, the radius of the curve, and the banking angle all affect the amount of centripetal force required for a banked curve.
4. How does the banking angle of a curve affect the required centripetal force?
The banking angle of a curve affects the direction of the centripetal force. A steeper banking angle requires a smaller centripetal force to keep the vehicle on the curve, while a flatter angle requires a larger centripetal force.
5. What happens if the centripetal force is not sufficient for a banked curve?
If the centripetal force is not sufficient for a banked curve, the vehicle will either slip towards the outside of the curve or slide towards the inside of the curve, depending on the direction of the net force acting on the vehicle. This can lead to loss of control and potentially cause an accident.
