Centripetal force due to banked curves
In summary: The net force on an object is the vector sum of all the forces acting on it (normally, gravity and the applied force). When the object is in circular motion, the applied force is the normal force. The normal force is always directed towards the center of the circle, and increases in magnitude as the velocity increases.
Mr Davis 97
1,462
44
I don't really understand how the centripetal force arises from driving on a banked curve. There are three forces acting on a car in circular motion on a banked curve: normal force, gravity, and applied force. Let's assume that there is no friction, and that somehow the car is already at a constant speed. In this case, there are only two forces; gravity and the normal force. Essentially, what allows the normal force to keep the car moving on the ramp? Assuming no friction, gravity will always pull the car down the ramp if its velocity is zero. However, when it's greater than some threshold, the car maintains its motion on the ramp. How does this work? Why does changing the velocity change your ability to stay on the ramp in constant motion? Why doesn't gravity just pull down in every case?
Car's inertia - tendency to go straight. Normal force keeps it on curve.
But whether the car is moving 0 m/s or 100 m/s does not change the free body diagram of the car. The normal force provides a centripetal force when the car goes a certain speed, but does not when it slows down; yet, the FBD is the same. This is what confuses me.
EDIT: Oh wait, I think I see... Is the situation analogous to an orbiting satellite? You must have a velocity (inertia) in order to not "fall" in ?
The motion isn't constant. The direction changes which means acceleration and requires a centripetal force.
Going down also reduces the path radius, which requires more horizontal centripetal force, which gravity cannot provide.
I need further elaboration on this. In the case where a car is just moving straight at a constant velocity with no friction, there are two forces which cancel out: gravity and the normal force. When the car reaches a banked curve and starts moving in uniform circular motion, the normal force cancels out gravity and provides the centripetal force. How is this possible. Why does the magnitude of the normal vector increase? What causes it to increase? Additionally, why does it cancel out gravity while proving a centripetal force? Why doesn't gravity just pull it down the curve?
Yes, normal force increases. That is because it is providing both the centripetal force and the supporting force that balances against gravity. Assuming that the curve is banked exactly right, the normal force is the vector sum of the two.
If the curve is not banked exactly right, friction makes up the difference.
Why does the magnitude of the normal vector increase? For the same reason that a table provides exactly the right support force to hold your bag of groceries in position. If it provided any less force, the groceries would move downward into the table. This increases the normal force. If it provided any more force, the groceries would rise off of the table, thus decreasing the normal force. A stable equilibrium is quickly (almost immediately) attained.
And for the last question: whether the car slides down or up in the curve depends on whether the forces actually balance: if the curve is banked to an angle that provides such a balance.
What is the physical cause for the increase in the normal force if a car is in uniform circular motion on a banked ramp as compared to a straight road? Why does this increase not occur when the car is on the banked ramp but with velocity of zero?
You seem to be asking what the cause is of the centripetal force: it is centripetal acceleration. F=ma.
Related to Centripetal force due to banked curves
1. What is centripetal force due to banked curves?
Centripetal force due to banked curves is the force that keeps an object moving in a circular path around a curved surface. It is directed towards the center of the circle and is necessary to maintain the object's circular motion.
2. How is centripetal force due to banked curves calculated?
The formula for calculating centripetal force due to banked curves is Fc = mv^2 / r, where Fc is the centripetal force, m is the mass of the object, v is the velocity, and r is the radius of the curve.
3. What is the role of the angle of bank in centripetal force due to banked curves?
The angle of bank is the angle at which the curved surface is tilted. It plays a crucial role in determining the necessary centripetal force for an object to maintain its circular motion. A greater angle of bank will require a smaller centripetal force, while a smaller angle of bank will require a larger centripetal force.
4. How does centripetal force due to banked curves affect the speed of an object?
Centripetal force due to banked curves affects the speed of an object by changing the direction of its velocity. As the object moves along the curved surface, the direction of its velocity constantly changes, resulting in a change in speed. The greater the centripetal force, the faster the object will travel.
5. What are some real-life examples of centripetal force due to banked curves?
Some real-life examples of centripetal force due to banked curves include vehicles navigating banked turns on a racetrack, roller coasters going around a curved track, and airplanes making turns while maintaining a constant altitude. In all of these scenarios, the curved surface and angle of bank play a crucial role in maintaining the object's circular motion.
  • Mechanics
  • Mechanics
