Ceramic Properties vs. Solid Properties
In summary, the speaker is trying to model thin film materials for thermal analysis, specifically Ti-Al-N. They are unsure of how to determine the number density of Nitrogen for a ceramic material, as most tables in school textbooks provide data for gas density. They are wondering if the density of the solid state can be used for modeling ceramics, and if there is a way to calculate the density from the ionic radii. The speaker also suggests using mass spectrometry or calculating the weight/volume of a repeating unit to determine the density.
shakystew
Hello,
Quick run-down: I am attempting to model thin film materials (e.g. Ti-Al-N) for thermal analysis. I am
confused on how to figure out the number density of Nitrogen for a ceramic. All
the tables I have in school textbooks are for gas (~0.0013 g/cm3). I can find
density of nitrogen/oxygen in a solid state, but is this the correct density?
Question: Is the density of the solid state the correct density to use for modelling ceramics? I realize
the structural differences, but not certain if the density can be estimated to be
the same.
Any assistance will be much appreciated!
The cutting edge of technology.
If you know the structure, maybe you can calculate the density from the ionic radii.
Calculate also for another similar material with a known density to check the method.
See the table here; http://en.wikipedia.org/wiki/Ionic_radius
It's pretty easy if you know the structure. If you don't then some sort of mass spec is your only hope on a real sample.
You basically need to find a repeating unit of structure then calculate the weight / volume of that repeating unit. On planar surfaces sometimes planar density is calculated as weight / area instead like graphene as it's thickness is pretty much non-existent.
If you have the chemical formula (which may not be consistent for a thin film if it is doped) you assume you have a repeating unit of the chemical formula calculate the percent mass of Nitrogen and multiply that by total mass/total volume. Similar to above, but easier.
Otherwise you do a mass spec of the results figure % mass nitrogen and divide by volume.
FAQ: Ceramic Properties vs. Solid Properties
1. What are the main differences between ceramic properties and solid properties?
Ceramic properties refer to the characteristics of materials made from non-metallic, inorganic compounds such as clay, while solid properties refer to the characteristics of materials that are made from a single solid piece, such as metals or plastics. The main differences between these two types of properties include their composition, strength, and heat resistance.
2. Can ceramic materials be considered solid?
While ceramic materials are technically solid, they have different properties compared to other solid materials such as metals and plastics. Ceramics are more brittle and have a lower density, making them less suitable for certain applications that require strength and durability.
3. What are the advantages of using ceramics over other solid materials?
Ceramics have many advantages over other solid materials, including their high resistance to heat and corrosion, as well as their ability to withstand high temperatures. They are also more lightweight and have a longer lifespan compared to some other materials.
4. Are there any disadvantages to using ceramics?
One of the main disadvantages of using ceramics is their brittleness, which makes them prone to cracking or breaking under stress. They also have a lower impact resistance compared to other solid materials, making them less suitable for certain applications.
5. How are ceramic properties affected by temperature changes?
Ceramic properties can be greatly affected by temperature changes. While ceramics are known for their high heat resistance, they can also be prone to thermal shock, which is when a sudden change in temperature causes them to crack or break. Additionally, extreme temperatures can also affect the strength and durability of ceramic materials.
