CFD Explained: Learn the Basics & Resources
  • Thread starter jonbonraki
  • Tags
    Cfd
In summary: However, that isn't realistic or possible for everyone. If you're looking to get into CFD, there's no harm in starting out with something a little more manageable, like a simulation run on your computer.
jonbonraki
can u guys tell me what exactly is CFD and hit me with some usual stuff like links and videos so that i can get good at it..
thanks in advance
Why do you want to get good at something if you don't know what it is?
i love to get good at what i don't know,dats how i stay hunger
beside i think i m going to come across it in my post graduation
An Advice: Never run this CFD analysis at your home desktop. It would screw the hell out of your RAM and processor.In simple words, CFD is the use of computer to predict the flow and its properties in various situations. Those computers are mostly many core processors operating in parallel and their solvers run from day to several weeks to get results
Of course it all depends on what kind of model you're running, and how many simultaneous equations you eventually try to solve. It's perfectly fine to run CFD on any computer you see fit, but the size of the simulation you can solve will be limited by the amount of ram and hard drive space you have available.
That is simply not true. I've ran tests on my laptop. It really depends on the problem to be solved. Will you solve a multistage turbine on your desktop? No. Can you solve a 100k node problem? Sure.
I've written some programs in Fortran and QBasic that perform CFD analysis. I ran a program in uncompiled QBasic...it took a while to run but you can get results on a desktop or laptop. In my case it was an older laptop without much computing capacity at all. If memory serves me correctly, the output file consisted of a direction and magnitude given the length of the model we setup to run. We then plotted the data on a grid with a certain length and direction to represent what was going on.
If anybody wants scans of the program, I'd be happy to provide them.
Of course it would be quicker and easier just to run this on a real CFD software.
FAQ: CFD Explained: Learn the Basics & Resources
What is CFD?
CFD stands for Computational Fluid Dynamics. It is a computer-based simulation technique used to analyze and solve problems related to fluid flow, heat transfer, and other related phenomena.
How does CFD work?
CFD works by breaking down a complex fluid flow problem into smaller, simpler equations that can be solved using numerical methods. These equations are then solved using powerful computers, allowing for the visualization and analysis of fluid flow behavior.
What are the applications of CFD?
CFD has a wide range of applications in fields such as aerospace, automotive, energy, and environmental engineering. It is used to optimize designs, improve performance, and reduce costs in various industries.
What are the benefits of using CFD?
The use of CFD offers several benefits, such as reducing the need for costly physical prototypes, providing insight into complex flow behavior, and allowing for the optimization of designs without the need for trial and error.
What are some resources for learning CFD?
There are many resources available for learning CFD, including textbooks, online courses, and software tutorials. Some popular software for CFD simulation includes ANSYS Fluent, OpenFOAM, and COMSOL Multiphysics.
