MHB Cfm4life's questions at Yahoo Answers regarding surface areas of solids
The discussion centers around calculating the surface areas of various geometric solids, including prisms, cylinders, pyramids, cones, and spheres. Each question presents specific dimensions, and detailed calculations are provided to determine the correct surface area for each shape. For example, the surface area of a square prism with a side length of 15 is calculated to be 1350, while a rectangular prism with dimensions 5, 6, and 3 yields a surface area of 126. The calculations also cover cylinders, with one example resulting in a surface area of approximately 803.8 for a cylinder with a radius of 8 and height of 8. The thread concludes with surface area results for various shapes, ensuring clarity in the mathematical processes used.
MarkFL
MHB
Here are the questions:
Perimeters and Areas?
Can someone please help on these questions please!
Question 1
Find the surface area of a square prism with a side measure of 15.
Answer
a) 1200
b) 900
C) 1350
d) 1260Question 2
Find the surface area of a rectangular prism with a height of 5, a length of 6, and a width of 3.
Answer
a) 120
b) 122
c) 124
d) 126
Question 3
Find the surface area of a cylinder with a radius of 8 and a height of 8. Use 3.14 for π. Round your answer to the nearest tenth.
Answer
a) 803.0
b) 803.8
c) 804.2
d) 805.1
Question 4
Find the surface area of a cylinder with a radius of 13 and a height of 7. Use 3.14 for π. Round your answer to the nearest tenth.
Answer
a) 1632.8
b) 1632.0
c) 1633.0
d) 1632.5
Question 5
Find the surface area of a square pyramid with a slant height of 16 and a base side measure of 14.
Answer
a) 638
b) 630
c) 644
d) 640
Question 6
Find the surface area of a square pyramid with a slant height of 9 and a base side measure of 6.
Answer
a) 146
b) 145
c) 144
d) 143
Question 7
Find the surface area of a cone with a slant height of 20 and a radius of 6. Use 3.14 for π. Round your answer to the nearest tenth.
Answer
a) 489.5
b) 489.8
c) 490.2
d) 489.4
Question 8
Find the surface area of a cone with a slant height of 19 and a radius of 7. Use 3.14 for π. Round your answer to the nearest tenth.
Answer
a) 571.4
b) 572.0
c) 571.5
d) 571.9
Question 9
Find the surface area of a sphere with a radius of 8. Use 3.14 for π. Round your answer to the nearest tenth.
Answer
a) 801.5
b) 802.6
c) 803.8
d) 804.5
Question 10
Find the surface area of a sphere with a radius of 3. Use 3.14 for π. Round your answer to the nearest tenth.
Answer
a) 111
b) 113
c) 114
d) 115
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Re: cfm4life's questions at Yahoo! Answers regarding surface are of solids
Hello cfm4life,
1.) Find the surface area of a square prism with a side measure of 15.
The surface area of a cube is compose of 6 squares, and if the side measure is $s$, then the area of one square is $s^2$ and so the surface area $S$ of the cube is:
$$S=6s^2$$
Using the given value for $s$, we then find:
$$S=6(15)^2=1350$$
Thus, c) is the answer.
2.) Find the surface area of a rectangular prism with a height of 5, a length of 6, and a width of 3.
The surface area $S$ of a rectangular prism if width $W$, length $L$ and height $H$ is composed of 3 pairs of rectangles, taken from the three ways to choose two of the three dimensions at a time. And so we have:
$$S=2(WL+WH+LH)$$
Using the given data, we find:
$$S=2(3\cdot6+3\cdot5+6\cdot5)=2(18+15+30)=2(63)=126$$
Thus, d) is the answer.
3.) Find the surface area of a cylinder with a radius of 8 and a height of 8. Use 3.14 for π. Round your answer to the nearest tenth.
The surface area $S$ of a cylinder is composed of the circular top and bottom and the rectangular side. The area of a circle can be found by taking the concentric circles that make up the area, straighten them, lay them side by side in increasing size to get a right triangle whose base is $r$ and whose height is $2\pi r$, and so the area of a circle is $$\frac{1}{2}(r)(2\pi r)=\pi r^2$$. For the rectangular side, the area of a rectangle is $bh$. The base of the rectangle is the circumference of the circle, or $2\pi 2$. Thus, we have:
$$S=2\pi r^2+2\pi rh=2\pi r(r+h)$$
$$S=2\pi 8(8+8)=256\pi\approx256\cdot3.14\approx803.8$$
Thus, b) is the answer.
4.) Find the surface area of a cylinder with a radius of 13 and a height of 7. Use 3.14 for π. Round your answer to the nearest tenth.
Using the formula we developed in question 3.), and the given data, we find:
$$S=2\pi 13(13+7)=520\pi\approx520\cdot3.14=1632.8$$
Thus, a) is the answer.
5.) Find the surface area of a square pyramid with a slant height of 16 and a base side measure of 14.
The surface area of a square pyramid is composed of the square bottom, and it its side measure is $s$, then its area is $s^2$, and the four triangular sides, whose bases are $s$ and whose altitudes $h$ and the slant heights. And so we have:
$$S=s^2+4\left(\frac{1}{2}sh \right)=s^2+2sh=s(s+2h)$$
$$S=14(14+2\cdot16)=14\cdot46=644$$
6.) Find the surface area of a square pyramid with a slant height of 9 and a base side measure of 6.
Using the formula we developed in question 5.) and the given data, we find:
$$S=6(6+2\cdot9)=6\cdot24=144$$
7.) Find the surface area of a cone with a slant height of 20 and a radius of 6. Use 3.14 for π. Round your answer to the nearest tenth.
The surface area of a cone is composed of a circular base and the lateral surface. If we decompose this lateral surface into all of the radii of the circles that ring it, and lay them side by side in increasing order, we get a right triangle whose base is equal to the slant height $\ell$ and whose height is that of the circumference of the base of the cone, or $2\pi r$. Thus the lateral surface area is $\dfrac{1}{2}(\ell)(2\pi r)=\pi r\ell$. And so we find:
$$S=\pi r^2+\pi r\ell=\pi r(r+\ell)$$
$$S=6\pi(6+20)=156\pi\approx156\cdot3.14\approx489.8$$
8.) Find the surface area of a cone with a slant height of 19 and a radius of 7. Use 3.14 for π. Round your answer to the nearest tenth.
Using the formula we developed for question 7.) and the given data, we find:
$$S=7\pi(7+19)=182\pi\approx182\cdot3.14\approx571.5$$
9.) Find the surface area of a sphere with a radius of 8. Use 3.14 for π. Round your answer to the nearest tenth.
If we decompose the surface $H$ of a hemisphere into the circles that ring it, and pair them smallest with largest, next smallest with next largest, and so on and lay them side by side, we find that the area they fill is a rectangle of base $r$ and height $2\pi r$, hence:
$$H=2\pi r^2$$
And so the surface area $S$ of a sphere, being twice that of a hemisphere of equal radius, is:
$$S=2H=4\pi r^2$$
$$S=4\pi(8)^2=256\pi\approx256\cdot3.14\approx803.8$$
10.) Find the surface area of a sphere with a radius of 3. Use 3.14 for π. Round your answer to the nearest tenth.
Using the formula we developed in question 9.) and the given data, we find:
$$S=4\pi(3)^2=36\pi\approx36\cdot3.14\approx113.0$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
