Automotive Can You Convert a Trike Differential Gear to a Chain Drive for a Kart?
Converting a trike differential gear to a chain drive for a kart is feasible but requires careful consideration of the design. The chain must enter and exit the differential housing while ensuring proper lubrication and structural integrity. Placing the sprocket on the differential input shaft and rotating the engine 90 degrees could be a viable solution. A significant reduction ratio will be necessary due to the high RPM of a small moped engine, typically requiring a smaller final chain sprocket. Overall, achieving this conversion involves balancing power transfer and mechanical strength.
synMehdi
Hi, I'm a beginner in mechanics so I need some help with a project I started. My project consists of a small kart-like car.
The car will be Rear-Wheel-Drive and Rear-Engine too (RR layout). and I am willing to use a small 110cc moped engine.
I have a trike Differential Gear for the rear shaft that I want to use. It has a prop shaft drive.
I want to change that and convert it into a Chain Drive Differential. Is it possible by adding Sprockets to the ring gear (and opening the differential housing to pass the chain)? can I put the Sprocket outside the housing? or is there a better solution?
My aim is to mount the chain directly between the engine and the Differential Gear.
I used Google Images and pasted in the title of your thread. I got some very helpful image hits... :smile:
You need to think clearly about how the chain can enter and leave the differential housing while maintaing adequate lubrication. If the sprocket is outside the housing, how do you transfer the power to the ring gear without compromising the strength of the differential housing? Is there any reason not to put the sprocket on the differential input shaft and turn the motor 90 degrees?
A small moped engine will have a fairly high RPM. You will need a significant reduction ratio set by the size of the chain sprockets. A differential typically has an internal pinion to crown wheel reduction ratio between 3 and 4. That makes the chain reduction ratio less of a problem as the final chain sprocket will be about one third the size needed if the crown wheel was directly driven.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
13K
11K
