Chain Rule in Multiple Variables
In summary, the chain rule works a little differently depending on how many different variables are involved.
cwill53
220
40
TL;DR Summary
I need help understanding the chain rule.
The following link leads to a question I asked on the mathematics Stack Exchange site.
https://math.stackexchange.com/ques...s/3791017?noredirect=1#comment7809514_3791017
I want to understand how the chain rule works, and what exactly the person who answered my question was saying. I haven't taken analysis and I know very little linear algebra, so it went over my head.
jedishrfu said:
Rather than discuss a Stack Exchange article, perhaps a more down-to-earth tutorial would be better:
https://tutorial.math.lamar.edu/classes/calciii/chainrule.aspx
or this video from Khan Academy:
https://www.khanacademy.org/math/mu...ariable-chain-rule/v/multivariable-chain-rule
It's not a stack exchange article, it's a specific question I have about how the chain rule changes if I have a function composed of different variables, where each variable is composed of its own set of variables.
My question is, how does the chain rule change when say
f = f(x,y) and x = x(u,v) and y = y(u,b)?
The variabes x and y are both functions of the variable u, but x is also a function of v while y is a function of b.
How about if say f = f(x,y) and x = x(u,v) while y = y(a,b)?
Now f depends on x and y but x and y depend on a completely different set of variables.
cwill53 said:
Summary:: I need help understanding the chain rule.
To answer your specific question. If you have ##f = f(x, y)## then you are defining ##f## as a function of two variables. There is some implicit rule for taking an ordered pair ##(x, y)## and outputing a number ##f(x, y)##.
If additionally you define ##x = x(u, v)## and ##y = y(a, b)##, you have two additional functions of two variables. We now have three different functions of two variables. This allows us to define a function of four variables (let's call it ##g##) where: ##g(u, v, a, b) = f(x(u, v), y(a, b))##.
The function ##g##, like any function of four variables, has four partial derivatives:
$$\frac{\partial g}{\partial u} = \frac{\partial f}{\partial x}\frac{\partial x}{\partial u}, \ \ \frac{\partial g}{\partial v} = \frac{\partial f}{\partial x}\frac{\partial x}{\partial v}, \ \ \frac{\partial g}{\partial a} = \frac{\partial f}{\partial y}\frac{\partial y}{\partial a}, \ \ \frac{\partial g}{\partial b} = \frac{\partial f}{\partial y}\frac{\partial y}{\partial b}$$
The next thing you should do is to test this out with an example. E.g.
$$f(x, y) = \cos(x)\sin(y), \ \ x(u, v) = 2u + 3v, \ \ y(a.b) = 2a^2 + b^3$$ which gives
$$g(u, v, a, b) = \cos(2u + 3v)\sin(2a^2 + b^3)$$
You can partially differentiate ##g## directly and then check the partial derivatives match the above formulas.
You may also be interested in these Insights on the multivariable chain rule:
https://www.physicsforums.com/insights/demystifying-chain-rule-calculus/
https://www.physicsforums.com/insights/how-to-solve-second-order-partial-derivatives/
Likes hutchphd, etotheipi, cwill53 and 1 other person
This was perfect! I understood it all. Thank you so much.
Likes PeroK
Related to Chain Rule in Multiple Variables
1. What is the chain rule in multiple variables?
The chain rule in multiple variables is a mathematical concept that allows us to find the derivative of a function with respect to multiple variables. It states that the derivative of a composite function is equal to the product of the derivatives of each individual function.
2. Why is the chain rule important in mathematics?
The chain rule is important because it allows us to find the rate of change of a function with respect to multiple variables. This is useful in many fields such as physics, economics, and engineering where multiple variables are often involved in a single equation.
3. How do you apply the chain rule in multiple variables?
To apply the chain rule in multiple variables, you first need to identify the composite function and its individual functions. Then, you can use the chain rule formula, which states that the derivative of a composite function is equal to the product of the derivatives of each individual function.
4. Can the chain rule be used for functions with more than two variables?
Yes, the chain rule can be used for functions with any number of variables. The formula remains the same, and you simply need to take the derivative with respect to each variable separately and then multiply them together.
5. What are some real-life applications of the chain rule in multiple variables?
The chain rule in multiple variables is commonly used in fields such as physics, economics, and engineering to find rates of change in complex equations. It is also used in optimization problems, where multiple variables are involved in finding the maximum or minimum value of a function.
  • Calculus
