Challenge problem #4 Is it possible for all n switches to be on at the end
In summary, the problem asks if it is possible for all $n$ switches to be on at the end, given that $n$ lights are arranged in a circle with each operated by exactly one of $n$ switches. It is possible if and only if $n\equiv0\text{ or }1\pmod4$. To prove this, we use induction with a step of 4. The base cases are $n=1$ and $n=4$, and the solution for $n=4$ is presented. Then, we show that if there is a solution for $n=k$, it can be extended to a solution for $n=k+4$. The solutions for $n=5$ and $
Olinguito
239
$n$ lights are arranged in a circle, each operated by exactly one of $n$ switches (with each switch operating exactly one light). Flicking a switch turns the light it is operating on if it is off, and off if it is on. Initially all the lights are off. The first person comes and flicks one of the swtiches, then the second person comes and flicks two of the switches, and so on, until the $n$th person comes and flicks all $n$ switches. Is it possible for all $n$ switches to be on at the end?
Mathematics news on Phys.org
[sp]
To prove that the condition is necessary, we note that each switch must be flicked an odd number of times. As the total number of flicks is $\dfrac{n(n+1)}{2}$, we must have:
$$\begin{align*}
n &\equiv\frac{n(n+1)}{2}\quad&\pmod2\\
2n &\equiv n(n+1)&\pmod4\\
n(n-1)&\equiv0 &\pmod4
\end{align*}$$
and, as $n$ and $n-1$ cannot both be even, the conclusion follows.
To prove that the condition is sufficient, we proceed by induction with a step of 4. The base cases are $n=1$ and $n=4$. The first case is obvious, and, for the second case, we have the solution:
\begin{array}{c|c|c|c|c|}
&1&2&3&4\\
\hline
1&1&0&0&0\\
2&0&1&1&0\\
3&1&1&1&0\\
4&1&1&1&1\\
\hline
\text{total}&3&3&3&1
\end{array}
where '1' stands for a flick, each column after the first corresponds to a switch and each row corresponds to a round.
We now assume that there is a solution for $n=k$ and show that we can extend it to a solution for $n=k+4$. We add 4 columns and 4 rows to the table.
The first $k$ rows are extended with 0. In the rows $k+1$ to $k+4$, we fill the first $k$ columns with 1, and the last 4 columns with a copy of the solution for $n=4$. This is indeed a solution, because:
  • Row $i$ contains $i$ 1's.
  • The parity of the first $k$ column totals has not changed; it is odd by the induction hypothesis.
  • The parity of the last 4 column totals is odd as it is in the case $n=4$.
The solutions for $n=5$ and $n=8$ are shown below:
\begin{array}[t]{c|c|c|c|c|c|}
&1&2&3&4&5\\
\hline
1&1&0&0&0&0\\
2&1&1&0&0&0\\
3&1&0&1&1&0\\
4&1&1&1&1&0\\
5&1&1&1&1&1\\
\hline
\text{total}&5&3&3&3&1
\end{array}
\qquad\begin{array}[t]{c|c|c|c|c|c|c|c|c|}
&1&2&3&4&5&6&7&8\\
\hline
1&1&0&0&0&0&0&0&0\\
2&0&1&1&0&0&0&0&0\\
3&1&1&1&0&0&0&0&0\\
4&1&1&1&1&0&0&0&0\\
5&1&1&1&1&1&0&0&0\\
6&1&1&1&1&0&1&1&0\\
7&1&1&1&1&1&1&1&0\\
8&1&1&1&1&1&1&1&1\\
\hline
\text{total}&7&7&7&5&3&3&3&1
\end{array}
[/sp]
Splendid! That is precisely the solution I have in mind. (Happy)
FAQ: Challenge problem #4 Is it possible for all n switches to be on at the end
Is it possible to have all n switches turned on at the end?
Yes, it is possible for all n switches to be turned on at the end of the challenge problem. This depends on the specific arrangement and number of switches, as well as the actions taken to manipulate them.
What factors determine if all n switches can be turned on?
The factors that determine if all n switches can be turned on include the number and arrangement of switches, the initial state of the switches, and the rules for manipulating them. Additionally, the solution may also depend on the specific problem constraints and limitations.
Can all n switches be turned on with a finite number of moves?
Yes, it is possible for all n switches to be turned on with a finite number of moves. However, the number of moves required will depend on the specific problem and the approach used to solve it.
What strategies can be used to solve this challenge problem?
Some strategies that can be used to solve this challenge problem include trial and error, logical reasoning, and mathematical techniques such as algebra and combinatorics. It may also be helpful to break the problem down into smaller, more manageable parts.
Are there any real-world applications for this challenge problem?
Yes, this challenge problem can have real-world applications in fields such as computer science, engineering, and game theory. It can also help develop critical thinking and problem-solving skills that can be applied to various situations.
