MHB Challenge Problem #6: Prove tan 18°=√(1-2/√5)
  • Thread starter Thread starter Olinguito
    Challenge Tan
The discussion focuses on proving that tan 18° equals √(1 - 2/√5) without using any computational tools. The proof is derived from the geometry of a regular pentagon, where the relationship between the lengths of the sides and diagonals is established. By applying the Pythagorean theorem within specific triangles formed in the pentagon, the relationship is confirmed. The geometric approach highlights the connection between the angles and side lengths, leading to the conclusion that tan 18° can be expressed in the desired form. This proof emphasizes both geometric intuition and analytical reasoning.
Olinguito
Prove that
$$\tan18^\circ\ =\ \sqrt{1-\dfrac2{\sqrt5}}.$$
No calculator, computer program, Excel, Google, or any other kind of cheating tool allowed. (Smirk)
Have fun!
Mathematics news on Phys.org
It's true. Proof: It's intuitively obvious.
-Dan
Olinguito said:
Prove that
[sp]This comes from the geometry of the pentagon.
[TIKZ][scale=0.75]
\coordinate [label=above: $C$] (C) at (90:5cm) ;
\coordinate [label=above right: $D$] (D) at (18:5cm) ;
\coordinate [label=above left: $B$] (B) at (162:5cm) ;
\coordinate [label=below: $A$] (A) at (234:5cm) ;
\coordinate [label=below: $E$] (E) at (306:5cm) ;
\coordinate [label=below: $P$] (P) at (-4.755,-4.045) ;
\coordinate [label=below: $R$] (R) at (4.755,-4.045) ;
\coordinate [label=above right: $Q$] (Q) at (0.45,0.6) ;
\draw (A) -- node
{$1$} (B) -- node[above left] {$1$} (C) -- node[above right] {$1$} (D) -- node
{$1$} (E) -- node[below] {$1$} (A) -- (P) -- (B) -- (D) -- (R) -- (E) ;
\draw (C) -- (E) -- node[above right] {$d$}(B) ;
\draw (-3.4,-3.75) node {$72^\circ$} ;[/TIKZ]
If $ABCDE$ is a regular pentagon with side $1$ then it is a standard result that the diagonals have length $d = \frac12(\sqrt5+1)$, the golden ratio. A quick way to see that is to notice that in the above diagram the triangles $CQD$ and $BQE$ are similar (with angles $36^\circ$ and $108^\circ$), from which $QD = \frac1d$. Then $BD = BQ+QD$, so that $d = 1 + \frac1d$, a quadratic equation whose positive root is the golden ratio.
If $BP$ and $DR$ are the perpendiculars from $B$ and $D$ to $AE$ then $d = PR = PA + AE + ER = 1+2PA$, from which $PA = \frac12(d-1) = \frac14(\sqrt5-1)$.
By Pythagoras in the triangle $BPA$, $BP^2 = 1 - \frac1{16}(\sqrt5-1)^2 = \frac18(5+\sqrt5)$. Therefore $$\frac{PA^2}{BP^2} = \frac{\frac18(3-\sqrt5)}{\frac18(5+\sqrt5)} = \frac{(3-\sqrt5)(5-\sqrt5)}{(5+\sqrt5)(5-\sqrt5)} = \frac{20-8\sqrt5}{20} = 1 - \frac2{\sqrt5}.$$ But $\frac{PA}{BP} = \tan 18^\circ$, and therefore $\tan 18^\circ = \sqrt{1 - \frac2{\sqrt5}}.$
[/sp]​
Thanks, Opalg! It’s a neat geometric solution. (Clapping)
My own solution is entirely analytic. (Nerd)
Consider $\tan54^\circ$. On the one hand:
$$\tan54^\circ\ =\ \frac1{\tan36^\circ}\ =\ \frac{1-\tan^218^\circ}{2\tan18^\circ}.$$
On the other hand:
$$\tan54^\circ\ =\ \tan3(18)^\circ\ =\ \frac{3\tan18^\circ-\tan^318^\circ}{1-3\tan^218^\circ}$$
using the triple-angle formula for tangent. Hence:
$$\frac{1-\tan^218^\circ}{2\tan18^\circ}\ =\ \frac{3\tan18^\circ-\tan^318^\circ}{1-3\tan^218^\circ}$$
$\implies\ 1-4\tan^218^\circ+3\tan^418^\circ\ =\ 6\tan^218^\circ-2\tan^418^\circ$
$\implies\ 5\tan^418^\circ-10\tan^218^\circ+1\ =\ 0$
$\implies$ $\tan^218^\circ$ is a root of the quadratic equation $f(x)=5x^2-10x+1=0$
$\implies\ \tan^218^\circ=\dfrac{10\pm\sqrt{80}}{10}=1\pm\dfrac2{\sqrt5}.$
But $f(1)=-4<0$ and $f(2)=1>0$ showing that there is a root between $1$ and $2$. This root can’t be $\tan^218^\circ$ as $0<\tan18^\circ<1$. It follows that $\tan^218^\circ$ is the lesser of the two possible roots, i.e.
$$\tan^218^\circ\ =\ 1-\frac2{\sqrt5}$$
and we are done. (Cool) (The other root turns out to be $\tan^254^\circ$.)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
