MHB Challenge Problem #9 [Olinguito]
  • Thread starter Thread starter Olinguito
    Challenge
The discussion addresses two assertions regarding permutations in the group S_n. The first assertion is confirmed as true, as the sum of the differences between the permutation and the identity is zero. The second assertion posits that the sum of absolute differences, σ_π, is even, which is also validated based on the first assertion. A bonus challenge involves determining the maximum value of σ_π, with preliminary findings suggesting it may equal ⌊n²/2⌋, though a formal proof is still needed. The exploration of these properties highlights interesting characteristics of permutations and their behavior in relation to their indices.
Olinguito
Let $S_n$ be the group of all permutations of the set $\{1,\ldots,n\}$. Determine whether the following assertions are true or false.
1. For each $\pi\in S_n$,
$$\sum_{i=1}^n\,(\pi(i)-i)\ =\ 0.$$
2. If
$$\sigma_\pi\ =\ \sum_{i=1}^n\,\left|\pi(i)-i\right|$$
for each $\pi\in S_n$, then $\sigma_\pi$ is an even number.
Bonus challenge: Find $\displaystyle\max_{\pi\in S_n}\,\sigma_\pi$.
Mathematics news on Phys.org
I have solved the first part of the problem.
$$\sum_{i=1}^n\,(\pi(i)-i))\ =\ 0$$
follows from the fact that
$$\sum_{i=1}^n\,\pi(i)\ =\ \sum_{i=1}^n\,i$$
(the terms of the LHS sum are precisely those of the RHS sum in a different order).
[sp]For the second part, notice that by the first part, the sum of the negative terms in $\sum(\pi(i) - i)$ is the negative of the sum of the positive terms. So when you replace the negative terms by their absolute values, the resulting sum is twice the sum of the positive terms. In other words, it must be an even number.
[/sp]
[sp]That part looks harder. After experimenting with small values of $n$, I believe that $$\max_{\pi\in S_n}\sigma_\pi = \bigl\lfloor\tfrac{n^2}2\bigr\rfloor$$. But I don't have a proof of that.
[/sp]
[/sp]
It would be $\dfrac{n^2}2$ if $n$ is even and $\dfrac{n^2-1}2$ if $n$ is odd – a simple induction clinches the proof.
Thanks for helping me with the challenge! (Clapping)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
