Challenging Logarithmic Integral: Exploring Different Methods
Thanks!In summary, the conversation discusses the problem of evaluating the integral $\int_{0}^{1} \frac{ln(1-x)ln(1+x)ln(1+2x)}{(1+2x)} \,dx$ and various methods to approach it. The conversation touches on using differentiation under the integral sign and expressing the integral in terms of special functions, as well as using series to evaluate integrals. One example of using series is shown for the integral $\int_{0}^{1} e^{2x} \,dx$. The conversation also briefly discusses the concept of a constant and how it relates to the sum $\sum_{n = 1}^\infty \frac{
Amad27
412
Hello,
The problem is
Is it even worth trying?
I haven't learned series yet, so if there are other methods, please let me know so I can start off. I did some differentiation under the integral sign, but it didnt work out well.
If anyone wants to see the approach I'll post it. Ideas?
Thanks!
Olok said:
Hello,
The problem is
Thanks!
Hi Olok,
I say this respectfully, but if you haven't learned series yet, you're not likely going to understand this problem even by method of differentiation under the integral sign. Regardless, here's a possible way to approach the problem. Consider
\(\displaystyle F(a,b,c) \stackrel{\text{def}}= \int_0^1 (1 - x)^a (1 + x)^b (1 + 2x)^c\, dx.\)
Using the differentiation rule $\frac{\partial}{\partial u} w^u = w^u \ln u$, we find that
\(\displaystyle \int_0^1 \frac{\ln(1 - x) \ln(1 + x) \ln(1 + 2x)}{1 + 2x}\, dx = \lim_{{{a \to 0 \atop b \to 0}\atop c \to -1}} \frac{\partial^3 F}{\partial a\, \partial b\, \partial c}(a,b,c).\)
You will need to express $F(a,b,c)$ in terms of some special functions before computing third derivatives.
Euge said:
Hi Olok,
Hello @Euge,
Unfortunately. I am still in high school, with less time to explore anything on my own. But I am very curious how you can use series for evaluating integrals.
Let's take a simple example.
$\int_{0}^{1} e^{2x} \,dx $
Can you quickly show me how you can use series to evaluate that specific integral? Just quickly, so I can get a feel for it =)
Thanks!
Olok said:
Hello @Euge,
Thanks!
Ok, if it helps!
Since \(\displaystyle e^x = \sum_{n = 0}^\infty \frac{x^n}{n!}\) for all real $x$, we have
\(\displaystyle \int_0^1 e^{2x}\, dx = \int_0^1 \sum_{n = 0}^\infty \frac{(2x)^n}{n!} = \sum_{n = 0}^\infty \frac{2^n}{n!} \int_0^1 x^n\, dx = \sum_{n = 0}^\infty \frac{2^n}{n!} \cdot \frac{1}{n+1}\)
\(\displaystyle = \sum_{n = 0}^\infty \frac{2^n}{(n+1)!} = \frac{1}{2} \sum_{n = 0}^\infty \frac{2^{n+1}}{(n+1)!} = \frac{1}{2} \sum_{n = 1}^\infty \frac{2^n}{n!} = \frac{1}{2} (e^2 - 1).\)
The justification for interchanging the series and integral is that power series may be integrated term-by-term within its interval of convergence (in this example, \(\displaystyle e^{2x}\) has an infinite radius of convergence).
Euge said:
Ok, if it helps!
Hello,
I might be a bit of a "non-knower" in this part but how is
$\sum_{0}^{\infty} \frac{2^n}{n!}$
This part a constant? How is this a constant that you can just pull out? In a simple question,
How is that expression a constant?
Thanks!
The expression doesn't depend on $x$. If that's not satisfying enough, plug in $x = 2$ in the formula
\(\displaystyle e^x = \sum_{n = 0}^\infty \frac{x^n}{n!}.\)
Doing so, you find that the value of the series in question is $e^2$, a constant.
Oh, so I have an idea.
A constant is one you cannot manipulate.
$x$ you can manipulate, it can change. Do you consider that a constant (the sum) because it is a sum??
That a sum is definite?
Thanks!
By definition a constant does not change value.
And the sum was a constant, because it was definite?
I am not sure what you mean by "definite". A constant is usually defined as a complex number. In this case, the sum
$$\sum_{n = 1}^\infty \frac{2^n}{n!}$$
converges (can you prove it). Thus, it is an element of $\Bbb C$.
I meant something similar.
@Euge pulled it out as considering it a constant.
I reasoned that,
$\sum_{n = 1}^\infty \frac{2^n}{n!}$ is a constant, because,
It is "definite." Meaning that that sum is one single number. As you said, it converges, so it is a single number.
The series converges by the ratio test. Indeed, since
\(\displaystyle \dfrac{\left|\frac{2^{n+1}}{(n+1)!}\right|}{\left|\frac{2^n}{n!}\right|} = \frac{2}{n+1} \to 0\) as \(\displaystyle n \to \infty\),
the ratio test ensures that the series \(\displaystyle \sum_{n = 0}^\infty \frac{2^n}{n!}\) converges.
Nice, so you have proved it converges.
Does that prove it is a constant? Yes, right?
I'm sounding a bit obnoxious because I haven't had a formal introduction to sequences and series yet -_- =D
Whether it is a constant or not is irrelevant of pulling it out from the integral. Consider
$$F(t) = \int_a^b t \cdot \sqrt{x} \, \mathrm{d}x$$
$F(t)$ is a function of $t$, thus $t$ most definitely isn't a constant. But as $t$ is independent of the argument $x$ of the integral, you can pull it out from the integral :
$$\int_a^b t \cdot \sqrt{x} \, \mathrm{d}x = t \int_a^b \sqrt{x} \, \mathrm{d}x$$
This is just another form of the distributive property of addition and multiplication : $$\begin{align}\sum_{n = a}^b f(t) g(n) &= f(t)g(a) + f(t)g(a+1) + \cdots + f(t)g(b) \\ &= f(t) \left [ g(a) + g(a+1) + \cdots + g(b) \right ] \\ &= f(t) \sum_{n = a}^b g(n)\end{align}$$
Wow, thanks @mathbalarka, that was an amazing explanation, I'd like to elaborate on that.
The "star" of my elaboration is, (I tweaked it for simplicity)
$f(t) \cdot \sum_{k = 1}^{n} g(x)$
$\lim_{{\left\lVert{\Delta}\right\rVert}\to{0}} f(t) \cdot \sum_{k = 1}^{n} g(x)$
Let there be $n$ subintervals (unequal length).
$f(t) \cdot \int_{a}^{b} g(x) \,dx$
Hello,
If you notice my latest comment, my summation nor the integral came out properly.
The summation has the index in the wrong place. How can I format the summation and the integral properly?
Thanks
Indeed, the correct Riemann sum should have been
$$\sum_{a \leq i < b} f(t)g(x'_i) \Delta x_i$$
For $\Delta x_i = x_{i+1} - x_i$ and $x'_i \in [x_{i+1}, x_i]$. Hence note that
$$\begin{align}\sum_{a \leq i < b} f(t) g(x'_i) \Delta x_i &= f(t) g(x'_a) \Delta x_a + f(t) g(x'_{a+1}) \Delta x_{a+1} + \cdots + f(t) g(x'_{b-1}) \Delta x_{b-1} \\ & = f(t)[g(x'_a)\Delta x_a + f(x'_{a+1})\Delta x_{a+1} + \cdots + f(x'_{b-1})\Delta x_{b-1}] \\& = f(t)\sum_{a \leq i < b} g(x'_i) \Delta x_i \end{align}$$
Thus let $\Delta x_i \to 0$ to get
$$\int_a^b f(t)g(x) dx = f(t) \int_a^b g(x) dx$$
A question and a comment.
comment first
I never seen that form of a Riemann-sum, I think what you have written might be related to measure theory. Interesting though. Question second
So when the part is unrelated it can be pulled out of the integral?
$\int_{a}^{b}f(x) t \,dx$
Implicitly, we define a variable $x$, and $t$
What is $t$?
Is $t$ a variable? Or
Is $t$ a constant?
What is it?
Thanks!
I think you are having terminological issues. The standard form of Riemann sum for $F$ defined on $[a, b]$ is
$$\sum_{a \leq n < b} F(x'_i) \Delta x_i$$
And I have used this for $F(x) = f(t)g(x)$, $t$ some variable independent of $x$.
What is t? Is t a variable? Or Is t a constant?
$t$ is either a constant or a variable independent of $x$, i.e., it's a constant "relative" to $x$.
Hello @mathbalarka.
When you say
$x'_i$
I have never learned what this $'$ means in this. I've seen that apostrophe several times, but I am not sure what the definition of that is.
second part,
Is there a theorem or definition, which perhaps states if
$t$ is either a constant or variable unrelated; independent to $x$ then it can be pulled out of an integral expression?
Thanks!
Olok said:
Hello @mathbalarka.
When you say
$x'_i$
$x'_i$ is a point inside $[x_i, x_{i+1}]$, I think I have mentioned it before.
I thought I had proved it above? :
It seems quite absurd, but I suppose that is how it is.
Pulling out a variable like $t$ is something new.
I suppose it it something new I've learned today!
Thanks =)
FAQ: Challenging Logarithmic Integral: Exploring Different Methods
What is an Insane Integral (Logarithmic)?
An Insane Integral (Logarithmic) is a type of mathematical integral that involves logarithmic functions. It is considered "insane" because it is notoriously difficult to solve, often requiring advanced techniques and mathematical tools.
What makes an Insane Integral (Logarithmic) difficult to solve?
Insane Integrals (Logarithmic) are difficult to solve because they often involve complex functions and require advanced mathematical techniques such as integration by parts, substitution, and trigonometric identities.
Can an Insane Integral (Logarithmic) be solved analytically?
Yes, an Insane Integral (Logarithmic) can be solved analytically, although it may require a combination of different mathematical techniques and tools. However, in some cases, an exact analytical solution may not be possible and numerical methods may be used instead.
What are some real-world applications of Insane Integrals (Logarithmic)?
Insane Integrals (Logarithmic) have various applications in fields such as physics, engineering, and economics. They are used to model complex systems and phenomena, such as radioactive decay, population growth, and economic growth.
Are there any tips for solving Insane Integrals (Logarithmic)?
Some tips for solving Insane Integrals (Logarithmic) include breaking them down into simpler integrals, using trigonometric identities or substitution, and being familiar with various integration techniques. It is also important to practice and have a good understanding of logarithmic functions and their properties.
