Change in concentration in equilibrium caused by addition
In summary, the conversation discusses the reaction between Cu2+ and Fe2+ ions, and the effect of adding different substances on the equilibrium. The equilibrium constant for the reaction is also mentioned. It is determined that adding solid copper will not change the concentration of Cu2+ ions, and any changes in solid substances will not affect the equilibrium.
TT0
211
Cu2+ ions react with Fe2+ ions according to the following reaction.
Cu2+ + 2Fe2+ --> Cu + 2Fe3+
At equilibrium, the concentration of Cu2+ ions is not changed by the addition of
  1. A) Cu2++
  2. B) Fe2+
  3. C) Cu
  4. D) Fe3+.
I chose A through elimination.
B won't work because the equilibrium will shift to the right if Fe2+ is added.
C and D won't work because the equilibrium will shift to the right.
Therefore A seems the most correct. However, if Cu2+ is added, then the equilibrium will also shift to the right. This means that it shifts to the right until the Cu2+ concentration is back to what it was before which seems impossible. Could someone shed some light on this?
Can you write formula for the equilibrium constant for this problem?
$$\frac {[Cu][Fe^{3+}]^2} {[Cu^{2+}][Fe^{2+}]^2}$$
This is the equilibrium constant. (took me a while to get the latex working)
Not exactly. Solid copper is not dissolved, so it doesn't have a concentration.
I see, so since it isn't dissolved, adding solid copper wouldn't change it's concentration. But won't it will still increase the backwards rate of reaction so it will still affect the Cu2+ concentration? This is the best I could come up with from the comment.
Changes in the amount of solid change both forward and backward reaction speed in exactly the same way, the net effect cancels out.
That's why there are no solids in the equilibrium formula (we assume activity of the solids equals exactly 1).
Likes TT0
I see, so as a rule, is this correct?
If solid reactants or products is added to a system already in equilibrium, the concentrations of all chemicals will stay the same; the reaction rate will increase equally in both directions.
Thank you very much!
And the equilibrium won't shift in any direction.
Likes TT0
Cheers! This is useful knowledge!
FAQ: Change in concentration in equilibrium caused by addition
Q1. How does adding a reactant affect the equilibrium concentration?
When a reactant is added to a system at equilibrium, the equilibrium shifts in the direction that consumes the added reactant. This means that the concentration of the reactant will decrease, while the concentration of the products will increase to maintain the equilibrium constant.
Q2. What happens to the equilibrium concentration when a product is added?
Adding a product to a system at equilibrium causes the equilibrium to shift in the direction that produces more of the added product. This leads to an increase in the concentration of the product, while the concentration of the reactants decreases to maintain the equilibrium constant.
Q3. Can adding a catalyst change the equilibrium concentration?
No, adding a catalyst does not affect the equilibrium concentration. A catalyst only speeds up the rate of the forward and reverse reactions, but does not change the position of the equilibrium or the equilibrium constant.
Q4. How does the direction of the equilibrium shift when a reactant or product is added?
The direction of the equilibrium shift depends on which substance is added. If a reactant is added, the equilibrium shifts to the right to produce more products. If a product is added, the equilibrium shifts to the left to consume more reactants.
Q5. Is there a limit to how much the equilibrium concentration can change due to addition of a substance?
Yes, there is a limit to how much the equilibrium concentration can change. This limit is determined by the equilibrium constant, which is a fixed value for a given reaction at a specific temperature. Once the system reaches this limit, the concentrations of the reactants and products will remain constant even if more substances are added.
