Change in Energy and Angular Momentum Upon Decreasing Orbit
In summary, a particle moving in a stationary, axisymmetric, spacetime with two Killing vector fields can be interpreted as moving in a circular orbit, and the change in energy and angular momentum during an orbital transfer can be related by the equation δE = ΩδL.
TeslaCoil137
A stationary, axisymmetric, spacetime has two Killing vector fields [ξt, ξφ] corresponding to translation along t or φ directions. A particle of unit mass moving in this spacetime has a four-velocity u = γ[ξt + Ωξφ].
(i) Explain why we can interpret this as a particle moving in a circular orbit.
(ii) Suppose the particle is acted upon by some dissipative forces making it lose energy by the amount δE and orbital angular momentum by the amount δL and move to another circular orbit of smaller radius. Show that δE = ΩδL
Conserved quantities: E = -p * ξt, L = p*ξφ, the energy and angular momentum of the orbit.
(i) The particle can be interpreted as moving in a circular orbit since the four velocity, u, can be rewritten as u= γ(1,0,0,Ω); clearly a circular orbit about the axis of symmetry.
(ii) I was thinking maybe an argument similar to the Penrose process but I cannot find an expression for the change in four velocity during this orbital transfer.
(i) Yes, the four-velocity can be interpreted as a circular orbit, as it represents a constant velocity in the φ direction while remaining stationary in the t direction. This is consistent with a circular orbit where the particle maintains a constant speed while moving in a circular path.
(ii) To show that δE = ΩδL, we can use the conserved quantities E and L. The change in energy, δE, can be expressed as the change in the timelike component of the four-momentum, δp0 = -δE. Similarly, the change in angular momentum, δL, can be expressed as the change in the spacelike component of the four-momentum, δpφ = δL. Using the conserved quantities, we can write:
δE = -p0 * ξt = -E = -γm,
δL = pφ * ξφ = L = γmΩ,
where m is the mass of the particle. Substituting these expressions into the given equation, we get:
δE = -γm = -γmΩ * δL = ΩδL.
Therefore, δE = ΩδL, which shows that the change in energy is proportional to the change in angular momentum, with the constant of proportionality being the orbital angular velocity Ω. This is consistent with the particle losing energy and angular momentum as it moves to a smaller orbit, as the particle's speed and orbital radius decrease.
Related to Change in Energy and Angular Momentum Upon Decreasing Orbit
1. How does decreasing orbit affect energy and angular momentum?
When an object decreases its orbit around another object, its energy increases while its angular momentum decreases. This is because the decrease in the distance between the two objects leads to an increase in the potential energy of the orbiting object, while the decrease in the radius of the orbit decreases its angular momentum.
2. What is the relationship between energy and angular momentum in a decreasing orbit?
The relationship between energy and angular momentum in a decreasing orbit is inverse. As the orbit decreases, the energy increases while the angular momentum decreases. This is due to the conservation of energy and angular momentum in orbital motion.
3. Can an object maintain its angular momentum while decreasing its orbit?
No, an object cannot maintain its angular momentum while decreasing its orbit. As mentioned earlier, the decrease in the radius of the orbit leads to a decrease in the object's angular momentum. However, the object can maintain its total energy, which is the sum of its kinetic and potential energy.
4. How does decreasing orbit affect the speed of an object?
When an object decreases its orbit, its speed increases. This is because, as the object moves closer to the central object, it experiences a stronger gravitational force, leading to an increase in its velocity. This increase in speed is necessary to maintain the object's angular momentum as its orbit decreases.
5. What factors affect the change in energy and angular momentum upon decreasing orbit?
The main factors that affect the change in energy and angular momentum upon decreasing orbit are the mass of the two objects, the initial distance between them, and the initial velocity of the orbiting object. These factors determine the strength of the gravitational force and the amount of kinetic energy the object possesses, which ultimately affect the change in energy and angular momentum during the decrease in orbit.
