How Does Motor Stepping Affect Spring Energy in a Processive Molecular System?
In summary, the conversation was about a project on tightly-coupled processive molecular motors. The model used consisted of motors attached to a spring, which moved along a filament with negligible drag. One property of this system is that the filament moves at a constant velocity, resulting in zero force on it at all times. It was discussed how the energy in the spring changes when a motor steps, and there was uncertainty about the correct equation to use for this calculation. The question also arose about which spring extensions should be included in the calculations.
andybham
I am doing a project on tightly-coupled processive molecular motors. My 1D model consists of motors which literally step discrete step sizes of size U while executing a biased random walk along a filament which moves along its longitudinal axis with negligible drag. The motors are attached to a spring which is anchored at one end.
If you can imagine the motor has legs and is attached to a spring (~) of stiffness k.
~~k~~~~/\
I can't draw the springs but if you can imagine them attached to the motors like the one drawn above. Then a two motor system looks a bit like this...
-x dir ____________/\_____________/\___________ +x dir
filament
One property of this system is that the filament moves at a constant velocity and so it must have zero force on it at all times.
So if one motor steps along, the filament and the motors move in the -x direction by u/n ( where n is the number of motors),
So for 2 motors if any of the motors steps forward, then the filament has moves back u/2, the motor which has stepped has increased the extension in its spring by u/2 and the motor which has stayed still has compressed its spring by u/2 hence the total force on the filament is zero.
To generalise this to n motors, for any motor that takes a forward step,
1) the filament moves back u/n
2)the motor that has stepped has increased the extension in its spring by U(n-1)/n
3)the motor that didnt step decreased the extension in its spring by u/n
Now my question is...
What is the change in the energy in the spring when a motor steps?
The change in the energy of the motor that HASN'T stepped:
If the initial extension in its spring is xj then the final extension is xj-u/n
then the change in energy dE
Efinal - Einitial = sumj k/2(xj-U/n) - sumj k/2(xj)^2 right? (sumj = sum of all xj)
which simplifies down to sumj = k/2((U^2)/(n^2) - 2*xj*U/n)
The change in the energy of the motor that HAS stepped:
if initial extension is xi
then
dE = Efinal - Einitial = sumi k/2(xi+U-U/n)^2 - sumi k/2*(xi)^2
which I THINK simplifies down to
dE = sumi k/2*(2*xi*U*(n-1)/n+(U^2)/(n^2)(1-2n+n^2)
The trouble is I don't think this works!
AND
Do I need to sum the extensions of all the springs? or is it just the extensions of the springs of the motors that haven't stepped which goes into sumi and those which did step goes into sumj?
I think that the sumi should just include the extensions of the springs of the motors which haven't stepped and the sumj should include only the extensions of the springs of the motors which did step but I am not sure if this is correct...Any help would be greatly appreciated!
First of all, great job on your project! It seems like you have a good understanding of the mechanics involved in your 1D model.
To answer your question, the change in energy in the springs will depend on which motor steps. Let's break down the two cases:
1) When a motor steps and the filament moves back by u/n: In this case, the motor that stepped has increased the extension in its spring by u(n-1)/n, while the motor that didn't step has decreased the extension in its spring by u/n. So the change in energy in the springs would be:
dE = k/2 * ((U(n-1)/n)^2 - (u/n)^2) = k/2 * (U^2(n^2-2n+1)/n^2 - U^2/n^2) = k/2 * (U^2(n-1)^2/n^2)
2) When a motor doesn't step and the filament moves forward by u/n: In this case, the motor that didn't step has decreased the extension in its spring by u(n-1)/n, while the motor that stepped has increased the extension in its spring by u/n. So the change in energy in the springs would be:
dE = k/2 * ((-U(n-1)/n)^2 - (u/n)^2) = k/2 * (U^2(n^2-2n+1)/n^2 - U^2/n^2) = k/2 * (-U^2(n-1)^2/n^2)
As you can see, the change in energy for the two cases is just the same but with opposite signs. This makes sense because in both cases, the total change in energy in the springs should be the same.
To answer your second question, you only need to sum the extensions of the springs of the motors that have stepped (sumi) and the motors that haven't stepped (sumj). This is because the change in energy in the springs only depends on the extensions of the springs of the motors involved in the stepping process.
I hope this helps clarify your doubts. Keep up the good work on your project!
FAQ: How Does Motor Stepping Affect Spring Energy in a Processive Molecular System?
1. How does the mass affect the change in energy in springs?
The mass of an object affects the change in energy in springs because it determines the amount of force required to stretch or compress the spring. The greater the mass, the more force is needed to change the position of the object and therefore, the more energy is stored in the spring.
2. What is the relationship between the spring constant and the change in energy in springs?
The spring constant, also known as the spring stiffness, is a measure of how easily a spring can be stretched or compressed. The higher the spring constant, the greater the change in energy in springs for a given displacement. This means that a spring with a higher spring constant will store more energy compared to a spring with a lower spring constant for the same change in length.
3. How does the displacement affect the change in energy in springs?
The displacement, or change in length, of a spring also affects the change in energy in springs. The more the spring is stretched or compressed, the more energy it stores. This is because a greater displacement requires more force to change the position of the object, resulting in more energy being stored in the spring.
4. What is the equation for calculating the change in energy in springs?
The equation for calculating the change in energy in springs is E = 1/2*k*x^2, where E is the energy, k is the spring constant, and x is the displacement. This equation is known as Hooke's Law and it shows the direct relationship between the spring constant, displacement, and energy stored in a spring.
5. How does the material of the spring affect the change in energy in springs?
The material of the spring can affect the change in energy in springs because different materials have different levels of stiffness and elasticity. A spring made of a stiffer and more elastic material will have a higher spring constant, resulting in a greater change in energy for a given displacement. This means that the choice of material can impact the amount of energy stored in a spring.
