Change in gravitational potential below the surface of the Earth
In summary, the gravitational potential becomes more negative as you move closer to a mass, and it is the most negative at the surface. However, as you move below the surface of a mass, the potential does not reach zero at the center but instead has a finite value. This can be calculated using calculus by taking into account the changing mass distribution.
MBBphys
Hi,
Infinitely far away from a mass-->gravitational potential is zero.
As get closer-->becomes negative.
At surface-->it is the smallest value of r, i.e. the radius of the mass, hence the most negative value for gravitational potential.
But as you go below surface of Earth (say Earth is the mass, and the only mass), what happens to the value of gravitational potential as you go below surface of the Earth?
V=-GM/r
I thought that, as the mass decreases by a cubic factor (volume), but the radius decreases by a linear factor, then the gravitational potential would increase (become more positive) by a factor to the power of 2, reaching zero at centre of earth?
Is this right?
Thanks!
Afraid not. Why would the potential be zero at the center ? Gravitation force IS zero there, though.
Compare (897) here with (4.10.3) http://web.mit.edu/8.02t/www/materials/StudyGuide/guide04.pdf
Thanks for your reply. Could you explain why it is not zero? As in, what would it be? A non-zero finite negative value? Infinite? What would it be?
MBBphys said:
what would it be?
Equation 897 at BvU's first link answers that. Just put r=0.
Once you move inside the radius of the Earth, the field gets weaker, but it is still directed towards the Earth's centre. So the potential must be still decreasing.
MBBphys said:
Hi,
V=-GM/r
Is this right?
Thanks!
If you know calculus already, the proper way to solve this would be to express the potential as an integral of the force divided by the test mass:
$$V(r) = -\int_r^\infty\frac{GM(r)}{r^2}dr$$
While you're above the Earth's surface, M is constant and the integral is simply the integral of ##\frac{1}{r^2}##. When you're below you replace M by ##\frac{4}{3}\pi\rho r^3## (with ##\rho## density of the Earth, if we consider it homogeneous, which it isn't but let's not go there). So the integral does not explode at ##r=0## and has instead a finite value, but still, it's not zero.
Without calculus I'm not sure how you can derive the correct formula, but you can realize at least that the rate of change of the potential never changes sign. If the potential is zero at infinity and negative at the surface, it would take a repulsive force to bring it back to zero, and that never happens. Even when you're below the surface all the layers above you merely cancel out their attraction to zero, they don't pull you upwards. So the potential keeps becoming more negative, it simply does so at a slower rate and does not become infinitely negative.
Related to Change in gravitational potential below the surface of the Earth
1. What is gravitational potential below the surface of the Earth?
Gravitational potential below the surface of the Earth refers to the amount of energy that an object possesses due to its position in the Earth's gravitational field. It is a measure of the work that would be required to move an object from its current position to a reference point, typically at infinity, without any change in its kinetic energy.
2. How does the gravitational potential change as you go below the Earth's surface?
The gravitational potential decreases as you go below the Earth's surface. This is because the pull of gravity from the Earth's center becomes stronger as you get closer to it, resulting in an increase in potential energy.
3. What factors affect the change in gravitational potential below the Earth's surface?
The change in gravitational potential below the Earth's surface is affected by the mass and density of the Earth. The greater the mass and density, the stronger the gravitational pull and the greater the change in potential as you go deeper below the surface.
4. How is the change in gravitational potential calculated below the Earth's surface?
The change in gravitational potential below the Earth's surface can be calculated using the equation: ΔU = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the depth below the surface.
5. Why is the change in gravitational potential important for understanding Earth's structure?
The change in gravitational potential provides valuable information about the distribution of mass and density within the Earth. By studying this change, scientists can gain insight into the Earth's internal structure and composition, as well as processes such as plate tectonics and mantle convection.
