Change in internal Energy During Expansion of an Ideal Gas
In summary, the internal energy of an ideal gas for expansion decreases as the gas is forced from its original volume to a greater volume. The decrease in internal energy is due to the work done by the surrounding pressure on the gas.
Purple Baron
Derive an expression for the change in internal energy of 1 mol of an ideal gas for expansion from volume [itex] V_i [/itex] to [itex]V_f [/itex] under constant pressure of 1atm where [itex] \gamma = \frac{C_p}{C_v}=\frac{5}{3} [/itex]
[itex] \Delta U=\frac{3}{2}nR\Delta T[/itex]
[itex]PV=nRT[/itex]
My first idea is to find a way to get the change in temperature, I tried to do this by finding the initial temperature saying that: [itex]T_i=\frac{PV_i}{nR}[/itex] and finding the final temperature by substituting this into [itex]T_f=\frac{V_{i}^{\gamma - 1}}{V_{f}^{\gamma - 1}}T_i[/itex] and substituting the equation obtained for initial temperature. From this I found change in temperature and substituted into the change in internal energy equation did the algebra and obtained [itex]\Delta U=\frac{3}{2}PV_i((\frac{V_i}{V_f})^{\gamma - 1}-1)[/itex]; however I'm not sure about the answer as the question also says you may use the fact that for 1 mol of an ideal gas [itex]C_p-C_v=R[/itex] however nowhere did I need to use this, indeed, R canceled out of my final expression also th internal energy in my expression is dependent on the pressure, which I know is not the case, so I am unsure this is a valid approach. Thanks.
This problem is way underspecified. They don't tell you whether the expansion takes place isothermally or adiabatically. They don't tell you whether the external pressure is initially higher than 1 atm (matching the initial gas pressure), and is then suddenly dropped to 1 atm, and held at that value until the gas stops expanding on its own, or whether the expansion is stopped before that.
The equation you employed assumes an adiabatic reversible expansion, but, if you check the pressure along the way using the ideal gas law, you will find that the only time the pressure is 1 atm is at the initial condition. So, it can't be an adiabatic reversible expansion.
The only thing you know for sure from the problem statement is that the external pressure is held constant at 1 atm. during the expansion. Since the work done on the surroundings is ##W = \int{P_{ext}dV}##, you can say that ##W = P_{ext}(V_f-V_i)##, where Pext is 1 atm.
I also think that they intended for you to assume that the expansion takes place adiabatically, since, if it took place isothermally, the change in internal energy would be zero. I also think that they intended for you to assume that external pressure was initially higher than 1 atm (matching the initial gas pressure), and then was dropped suddenly to 1 atm., and held at that value until the gas stopped expanding on its own. But, we don't know either of these things for sure.
Chet
The equation [itex]T_f=\frac{V_{i}^{\gamma - 1}}{V_{f}^{\gamma - 1}}T_i[/itex] is for an adiabatic process. Your exercise is for a constant pressure process.
You need the temperature change. You already have [itex]T_i=\frac{PV_i}{nR}[/itex]. Can you write a very similar expression for ##T_f## in terms of ##V_f##?
[itex]PV=nRT[/itex]
For an ideal gas, the inernal energy is a function of temperature only.
You know Pi, Vi, n, Pf, Vf (Pi = Pf = 1 atm; n = 1 mol). You need an expression for Delta T in terms of Vi, Vf, and the constants (n, R, P) which you can then plug into the expression for Delta U.
[You did indeed use the fact that gamma = 5/3 to determine a value for C_v -- that you used in the expression for Delta U. ]
Ah. I think TSny has nailed it. They want you to assume that the external pressure is held constant (at 1 atm) while you add heat to make the gas expand (starting and ending at 1 atm pressure). So, it's neither adiabatic nor isothermal. That makes sense.
Chet
Well as it is constant pressure I could use the equation [itex]T_f=\frac{T_i V_f}{V_i}[/itex] substituting initial temperature from the other equation gives [itex]T_f=\frac{PV_f}{R}[/itex] and substitution into the internal energy equation gives [itex]\Delta U=\frac{3}{2}P(V_f-V_i)[/itex] Is this ok?
Thanks for the help everyone.
The number of moles should appear in this expression somewhere. Note that another way to obtain the expression is just by rearranging the ideal gas law for T.
..substitution into the internal energy equation gives [itex]\Delta U=\frac{3}{2}P(V_f-V_i)[/itex] Is this ok?
Looks good.
Related to Change in internal Energy During Expansion of an Ideal Gas
1. What is internal energy?
Internal energy refers to the total energy of a system, which includes the kinetic and potential energies of all its particles. It is a measure of the system's microscopic energy and is affected by factors such as temperature, pressure, and volume.
2. How does an ideal gas expand?
An ideal gas expands when its volume increases due to an increase in temperature or a decrease in pressure. This causes the gas particles to move further apart from each other, resulting in an increase in the system's internal energy.
3. What happens to the internal energy of an ideal gas during expansion?
The internal energy of an ideal gas increases during expansion as the gas particles gain kinetic energy due to their increased speed. This increase in internal energy is accompanied by a decrease in temperature, as the gas particles' average kinetic energy decreases.
4. How is the change in internal energy during expansion calculated?
The change in internal energy during expansion can be calculated using the equation ΔU = Q - W, where ΔU is the change in internal energy, Q is the heat absorbed by the gas, and W is the work done by the gas. In the case of an ideal gas, there is no change in internal energy due to work, so ΔU = Q.
5. Is the change in internal energy always positive during expansion of an ideal gas?
No, the change in internal energy during expansion of an ideal gas can be either positive or negative. It depends on the specific conditions of the expansion, such as the amount of heat added or removed from the system. If more heat is added than work done by the gas, the change in internal energy will be positive, and vice versa.
