Change in internal energy of an ideal gas
In summary, when dealing with an ideal gas, the change in internal energy can be calculated using the equation ΔU = (3/2)PV, where both the initial and final pressure and volume must be known. This is a variation of the ideal gas law and can also be expressed as ΔU = (3/2)NkTΔT. For a closed system, only a change in temperature will result in a change in energy, and isothermal processes on ideal gases have a condition of ΔU = 0. However, the first law of thermodynamics, ΔU = Q + W, is also useful in finding the change in internal energy and can be applied in many problems.
awesomeness
Given that U = (3/2)PV does this mean that ΔU = Δ(3/2)PV for an ideal gas? Hence when finding the change in internal energy using a P-V diagram, can we simply apply this equation instead of using ΔU = Q+W?
Yes, if you can know ##\Delta(PV)## you can know the change in internal energy. For this formula, you have to know both the initial and final pressure and volume. A more often seen version of this concept is using the other side of the ideal gas law, so that with constant N:
$$\Delta U = \frac{3}{2}Nk_T \Delta T$$
Thus, for a closed system, only a change in temperature will lead to a change in energy. Specifically, isothermal processes on ideal gases have the condition ##\Delta U =0##.
But ##\Delta U=Q+W## is the first law of Thermodynamics. It can come in very useful when you're finding either ##\Delta U## or ##Q## or ##W##. Often you will have to use this law in some form or another in many problems.
Likes 1 person
Related to Change in internal energy of an ideal gas
1. What is the definition of change in internal energy of an ideal gas?
The change in internal energy of an ideal gas refers to the difference between the initial and final internal energies of the gas. It is a measure of the energy transferred to or from the gas in the form of heat or work.
2. How is the change in internal energy of an ideal gas calculated?
The change in internal energy of an ideal gas can be calculated using the equation ΔU = Q - W, where ΔU is the change in internal energy, Q is the heat added to the gas, and W is the work done by the gas.
3. What factors affect the change in internal energy of an ideal gas?
The change in internal energy of an ideal gas is affected by the amount of heat added or removed, the work done on or by the gas, and the initial and final temperatures of the gas.
4. Is the change in internal energy of an ideal gas always positive?
No, the change in internal energy of an ideal gas can be positive or negative. A positive change indicates an increase in the internal energy of the gas, while a negative change indicates a decrease in internal energy.
5. What is the significance of change in internal energy of an ideal gas?
The change in internal energy of an ideal gas is important in understanding the thermodynamic properties of gases and their behavior. It is also a key factor in determining the efficiency of heat engines and other thermodynamic processes.
  • Other Physics Topics
