Change in orbital magnetic dipole moment of the electron due to unifrom B field
In summary: JohnIn summary, the conversation discusses the calculation of the change in the orbital magnetic dipole moment of an electron in a circular orbit due to a perpendicular magnetic field. The correct expression for this change is μ = e2Br2/2m, and the discrepancy with the textbook's answer of e2Br2/4m is most likely due to a typo or different units being used.
dlslhc
Assume that an electron of mass m and charge magnitude e moves in a circular orbit of radius r about a nucleus. A uniform magnetic field B is then established perpendicular to the plane of the orbit. Assuming also that the radius of the orbit does not change and that the change in the speed of the electron due to field B is small, find an expression for the change in the orbital magnetic dipole moment of the electron due to the field.
F = qvB = mv2/r => v = eBr/m
μ = evr/2
i calculated μ = e2Br2/2m
but the answer from textbook is e2Br2/4m , where is the 2 come from or the text is wrong? thank you
Hello,
Thank you for your question. Your attempt at the solution is correct. The expression for the orbital magnetic dipole moment of an electron due to a perpendicular magnetic field is indeed μ = e2Br2/2m. The textbook answer is most likely a typo. The 2 in the denominator should not be there. It is also possible that the textbook is using a different set of units, in which case the expression would be different. However, assuming that both you and the textbook are using SI units, your answer is correct.
I hope this helps. Let me know if you have any further questions.
Thank you for your question. It appears that the textbook may have a typo or error in their solution. In your solution, you have correctly calculated the orbital magnetic dipole moment of the electron due to the uniform magnetic field. The textbook's answer of e2Br2/4m is incorrect as it does not take into account the correct expression for the velocity of the electron in a circular orbit, which is v = eBr/m. Your solution of e2Br2/2m is the correct expression for the change in the orbital magnetic dipole moment of the electron due to the uniform magnetic field.
Related to Change in orbital magnetic dipole moment of the electron due to unifrom B field
1. What is the orbital magnetic dipole moment of an electron?
The orbital magnetic dipole moment of an electron is a measure of the strength and direction of the magnetic field created by the electron's orbital motion around an atom's nucleus.
2. How does a uniform magnetic field affect the orbital magnetic dipole moment of an electron?
A uniform magnetic field can cause the electron's orbital magnetic dipole moment to change in magnitude and direction. This change is known as precession and is caused by the torque exerted on the electron by the magnetic field.
3. Can the orbital magnetic dipole moment of an electron change without a magnetic field?
No, the orbital magnetic dipole moment of an electron is only affected by the presence of a magnetic field. Without a magnetic field, the electron's orbital magnetic dipole moment remains constant.
4. What factors determine the magnitude of the change in orbital magnetic dipole moment of an electron due to a uniform magnetic field?
The magnitude of the change in orbital magnetic dipole moment depends on the strength of the magnetic field, the speed of the electron's orbital motion, and the angle between the direction of the electron's orbital motion and the magnetic field.
5. What are the practical applications of understanding the change in orbital magnetic dipole moment of an electron?
Understanding the change in orbital magnetic dipole moment is important in various fields such as materials science, quantum mechanics, and astronomy. It can also be applied in technologies such as magnetic resonance imaging (MRI) and particle accelerators.
