Change in potential energy across wires differing composition
In summary, the conversation discusses the calculation of potential difference across three different materials in a series circuit, connected to a 9 V battery. The materials include 10 cm copper, 12 cm iron, and 18 cm tungsten, all with a diameter of 0.26 mm. Using the equation R=pl/A, the resistances for each material are calculated to be 0.032 ohm for copper, 0.22 ohm for iron, and 0.19 ohm for tungsten. The total resistance in the series is found to be 0.442 ohm. Using the formula V=IR, the potential differences across each material are calculated to be 0.65 V for copper,
Mebmt
1. Homework Statement
9 V battery is connected to wire made up of three segments of different materials connected in a series: 10 cm copper, then 12 cm iron, then 18 cm tungsten. All wires are 0.26 mm diameter. Find potential difference across each wire.
Constants:
p Copper= 1.7 x 10-8
p Iron = 9.7 x 10 -8
p Tungsten = 5.6 x 10-8
26 mm diameter = 0.13 mm radius or 1.3 x 10-4 m
R=pl/A
area of wire (1.3 x 10-4)(1.3 x 10-4) x pi = 5.31 x 10-8 meters squared
Copper Resistance
R=pl/a
R= (1.7 x 10-8 ohm m)(.1m)/5.31 x 10-8 meters squared
R=0.032 ohm
Iron Resistance
R=pl/a
R=(9.7 x 10-8 ohm m)(.12m)/5.31 x 10-8 meters squared
R=0.22 ohm
Tungsten Resistance
R=pl/a
R=(5.6 x 10-8 ohm m)(0.18 m)/5.31 x 10-8 meters squared
R=0.19
R total series = r1 + r2 + r3
= .032 + .22 + .19
= 0.442 ohm
V copper = vtotal * Rcopper/R total
= 9 V * .032/.442
= 0.65 V
V silver = vtotal *Rsilver/R total
=9 V * .22/.442
=4.48 V
V Tungsten = vtotal * Rtungsten/R total
=9V *.387/.442
= 3.87 V
Volts all add up to 9 so 2nd Law is good but my answers are wrong somewhere...
Thanks,
Scott
Constants:
R=pl/A
Copper Resistance
R=pl/a
R=0.032 ohm
Iron Resistance
R=pl/a
R=0.22 ohm
Tungsten Resistance
R=pl/a
R=0.19
= .032 + .22 + .19
= 0.442 ohm
= 9 V * .032/.442
= 0.65 V
=9 V * .22/.442
=4.48 V
=9V *.387/.442
= 3.87 V
Thanks,
Scott
I like your reasoning - and your answers - so check that you have transcribed the figures correctly, and looked at the correct answers in you book.
Thanks Peter. The prof had changed the numbers on the website from those provided in the book. I had overlooked one of them.
Note: when I worked this out I ignored the diameter - since they were all the same, as well as the 10-8 on each of the resistivities, [they all had the same factor] since I knew at the end I was only going use the resistances in the form of fractions - where those values would cancel anyway.
I would like to point out that the potential energy across wires differing in composition is a result of the different resistances of each material. This is due to the different properties of each material, such as their electrical conductivity and resistivity. The potential difference across each wire can be calculated using Ohm's Law, which states that the potential difference (V) is equal to the current (I) multiplied by the resistance (R). In this case, the current is the same throughout the series circuit, so the potential difference is directly proportional to the resistance of each wire.
Your approach in calculating the resistance of each wire is correct. However, the total resistance in a series circuit is not simply the sum of the individual resistances, but rather the sum of each resistance multiplied by the length of the wire. This is because the current must pass through each segment of wire, and the longer the wire, the higher the resistance. Therefore, the correct equation for the total resistance in this circuit would be:
R total = R copper * (10 cm/100 cm) + R iron * (12 cm/100 cm) + R tungsten * (18 cm/100 cm)
= 0.032 ohm + 0.22 ohm + 0.19 ohm
= 0.442 ohm
Using this value for the total resistance, we can then calculate the potential difference across each wire using Ohm's Law:
V copper = 9 V * (0.032 ohm / 0.442 ohm) = 0.65 V
V iron = 9 V * (0.22 ohm / 0.442 ohm) = 4.48 V
V tungsten = 9 V * (0.19 ohm / 0.442 ohm) = 3.87 V
As you can see, the total potential difference across all three wires adds up to 9 V, indicating that the second law of thermodynamics is satisfied. I would also like to note that the diameter of the wires is not relevant in this calculation, as the resistance is determined by the length and cross-sectional area of the wire.
In conclusion, the change in potential energy across wires differing in composition is due to the different resistances of each material, which can be calculated using Ohm's Law. The total resistance in a series circuit is not simply the sum of the individual resistances, but rather
Related to Change in potential energy across wires differing composition
1. What is potential energy?
Potential energy is the energy stored in an object or system based on its position or configuration.
2. How does potential energy change across wires of different compositions?
The potential energy across wires of different compositions depends on the type and arrangement of atoms or molecules in the wire. This can affect the strength of the intermolecular forces and thus the amount of potential energy stored in the wire.
3. Can changing the composition of a wire affect its potential energy?
Yes, changing the composition of a wire can affect its potential energy. Different types of atoms or molecules have different intermolecular forces, which can result in different amounts of potential energy being stored in the wire.
4. How does potential energy impact the behavior of wires made of different materials?
The potential energy in a wire can affect its behavior by influencing its physical properties, such as stiffness and elasticity. This can also impact the wire's ability to conduct electricity and heat.
5. What factors can cause changes in potential energy across wires of differing composition?
Changes in potential energy across wires of differing composition can be caused by variations in the types and arrangements of atoms or molecules, as well as external factors such as temperature and pressure.
