Thomas_Kellner
- 5
- Homework Statement
- Assume you have a candle inside a drinking glass (cylinder turned upside down) that burns for
10 s.
You know the following values.
Air density = 1.2 kg/m^3
Diameter of the cylinder = 6,5 cm
Height of the cylinder = 6 cm
Initial temperature = 293,15 K
Heating power of the candle = 30 W
Time = 10 s
Specific heat capacity of air = 1 KJ/kg*K
Calculate the final temperature of the air inside the glass.
- Relevant Equations
- c = Q/m*ΔT
Q = P*t
Looking at the given values, I thought the specific heat formula could be used to calculate the final temperature of the air: c = Q/mΔT. Since the final temperature is the sum of the initial temperature and the change in temperature, the formula can be rearranged to ΔT = Q/m*c.
Q = 30 W * 10 s = 300 J
V = A * h = (π * r^2) * 6 cm = (π * 3,25 cm^2) * 6 cm = 33,2 cm^2 * 6 cm = 199 cm^3
m = V * p = 0,000199 m^3 * 1,2 kg/m^3 = 0,00024 kg
c = 1 KJ/kg*K
ΔT = Q/m*c = 0,3 KJ/(0,00024 kg * 1KJ/kg*K) = 1250 K
Final temperature = 1250 K + 293,15 K = 1543,15 K
This number seems physically impossible, so I conducted the experiment with an initial temperature of 293,15 K, the same air volume and a normal tealight that burned for approximately 10 s. The oven thermometer inside showed a final temperature of about 304,15 K, meaning ΔT = 11K. What did I do wrong?
c = 1 KJ/kg*K
