Change of Basis and Unitary Transformations
In summary: This is consistent with what you wrote below.Now, if we write the old basis vectors ##\{v_j\}## in terms of the new basis,$$v_j=\sum_iS_{ij}w_i=Sw_j$$Yes, this is consistent with the definition ##Uw = Sw##, and it is also consistent with the equation ##Uv_j = \sum_i U_{i,j} v_i## that defines ##U## in terms of the ##v##-basis.Comparing the two equations for ##v_j##, we see that ##S=U^{-1}.##Yes, that is correct, if we use the definitions above.In fact, we can write the the operators
devd
47
Say, we have two orthonormal basis sets ##\{v_i\}## and ##\{w_i\}## for a vector space A.
Now, the first (old) basis, in terms of the second(new) basis, is given by, say,
$$v_i=\Sigma_jS_{ij}w_j,~~~~\text{for all i.}$$
How do I explicitly (in some basis) write the relation, ##Uv_i=w_i##, for some unitary matrix, ##U##?
What is the relation between the matrix formed by the numbers ##S_{ij}## and ##U##?
The [tex]S_{ij} [/tex] form a matrix. U is its inverse.
Likes devd
How do I see this explicitly?
Can you see how the simultaneous equations
can be expressed as an equation involving matrices?
It's the same idea as expressing
1) ##ax + by = c##
2) ##dx + ey = f##
as
##\begin{pmatrix} a & b \\ c & d \end{pmatrix} \begin{pmatrix} x \\ y \end{pmatrix} = \begin{pmatrix} c \\f \end{pmatrix}##
Likes devd
1) ##ax + by = c##
2) ##dx + ey = f##
as
Yes, but where I got confused was that the entries of the column vectors themselves are vectors.
$$v_j=\sum_jS_{ij}w_i,~~~~\text{for all}~ j.$$
The ##v_j~'s ## and ##w_i~'s## in the equation above are not numbers but vectors.
But, I think, I have figured it out.
Let, U be a linear transformation on the vector space A, and ##\{v_j\}## be a basis. Then,
$$Uv_j=\sum_iU_{ij}v_i$$
Now, we define
$$\sum_iU_{ij}v_i=w_j\\ \implies v_j=U^{-1}w_j$$
In fact, we can write the the operators, ##U## and ##S## as outer products of the basis vectors,
$$U=\sum_j v_j\otimes v_j\\ S=\sum_i w_i \otimes w_i.$$
Do you think this makes sense? Or are there still some lacunae in my understanding?
You need to have a "##v_i##" instead of a "##v_j##" on the left hand side of that equation.
Yes, the terms involved in that sum , ##S_{i,j} w_i##, are vectors, but we aren't yet dealing with any representation of ##w_i## as a vector of numbers. So, effectively, ##w_i## plays the role of a variable, just like the typical uses of "##x##" and "##y##".
Yes, those equations ( considering all ##i##) define a linear transformation ##U## expressed in the ##v##-basis.
To interpret each equation as involving a matrix multiplication ##U v_j = b_j##, we must adopt some convention about how ##v_j## is represented as a column vector. Using "##v_j##" as ambiguous notation, we could say that ##v_j## represents a column vector of "variables" that are all zeroes except for the variable "##v_j##" in its ##j##th entry. Or we could say that ##v_j## ( in ##v##-basis) will be a column vector with a 1 in the ##j##th entry of the column and zeroes elsewhere. So interpreting the left hand side of the equation as matrix multiplication does involve a some convention about how ##v_j## is represented as a column vector.
We must also adopt a similar convention about the column vector on the right hand side. We might say it represents a linear combination of vectors from the ##v##-basis and that the ##k##th entry of the column vector on the right side the equation represents the coefficient of ##v_k## in the linear combination.
Now, we define
$$\sum_iU_{ij}v_i=w_j$$
It isn't clear what you are defining. Are you defining ##U## or are you defining the ##w_j## ?
If we take the ##w##-basis as given, you are defining ##U## as a matrix whose ##j##th column consists of the coefficients needed to express ##w_j## as a linear combination of vectors in the ##v##-basis.
However, the usual way to express the ##w##-basis in terms of the ##v##-basis in matrix form would be to consider the column vector ##w = (w_1,w_2,w_3,..)## as the ##w##-basis expressed as a vector of "variables", and the column vector ##w = (v_1,v_2,v_3,...)## as the ##v##-basis expressed a vector of variables, and to define the matrix ##U## to satisfy ##w = Uv##.
This definition would imply ##w_i = \sum_j U_{i,j} v_j ##, so the summation is over the column index "##j##" instead of the row index "##i##".
FAQ: Change of Basis and Unitary Transformations
What is a change of basis?
A change of basis is a mathematical operation that transforms a vector from one coordinate system to another. It involves expressing the vector's components in terms of a new set of basis vectors.
Why is a change of basis important?
A change of basis is important because it allows us to view the same vector or linear transformation from different perspectives. This can often simplify calculations and provide a deeper understanding of the underlying structure.
What is a unitary transformation?
A unitary transformation is a type of linear transformation that preserves the length and angles between vectors. It is also known as an orthogonal transformation, as it preserves orthogonality.
How is a change of basis related to a unitary transformation?
A change of basis can be achieved through a unitary transformation. By using a unitary matrix, we can perform a change of basis without altering the properties of the original vector or linear transformation.
What are some real-world applications of change of basis and unitary transformations?
Change of basis and unitary transformations have many applications in physics, engineering, and computer science. They are used in quantum mechanics, signal processing, data compression, and image processing, among others. They also play an important role in solving systems of linear equations and in finding eigenvalues and eigenvectors of a matrix.
