Change of order in double integrals
In summary, the question asks about the possibility of changing the order of the integral in order to make y the independent variable and x the dependent one. The conversation also mentions a cylinder and planes that intersect to form a region in the first octant. The question asks for an explanation of the significance of x in relation to the volume of the solid.
Jazzyrohan
32
In the question given below, can we change the order of integral so that y can be the independent variable and x be the dependent one?The cylinder x^2 + z^2 = 1 is cut by the planes y=0,z=0 and x=y.Find the volume of the region in the first octant.This may look like a homework question but it's not.I just want to know whether what I have asked is possible and if yes,then how so?
Why is ##x## special? In which way are ##x, y## and ##z## fundamentally different when it comes to the volume of a solid?
Related to Change of order in double integrals
1. How do you determine the new limits of integration when changing the order of a double integral?
When changing the order of a double integral, you must first identify the new limits of integration by considering the original region of integration. The new limits will be determined by the equations of the lines that form the boundary of the region, and may involve changing the variable of integration.
2. Can you change the order of integration for any double integral?
Yes, the order of integration can be changed for any double integral as long as the region of integration is not dependent on the order of integration. In other words, the boundaries of the region must remain the same regardless of the order of integration.
3. What is the purpose of changing the order of a double integral?
Changing the order of a double integral can make the integration process easier, especially if one variable is easier to integrate with respect to than the other. It can also help to visualize and understand the geometric interpretation of the integral.
4. Are there any rules or guidelines to follow when changing the order of a double integral?
Yes, there are a few rules to follow when changing the order of a double integral. These include making sure the new limits of integration are correct, ensuring that the integrand is properly written in terms of the new variables, and verifying that the order of integration is appropriate for the given problem.
5. Can you change the order of integration for triple or higher order integrals?
Yes, the order of integration can also be changed for triple or higher order integrals. The same principles apply as for double integrals, but the process may become more complex due to the additional variables and boundaries involved.
  • Calculus
  • Calculus
