harpazo
- 208
- 16
Let S S = double integrals
S S x^2 dA; where R is the region bounded by the ellipse
9x^2 + 4y^2 = 36.
The given transformation is x = 2u, y = 3v
I decided to change the given ellipse to a circle centered at the origin.
9x^2 + 4y^2 = 36
I divided across by 36.
x^2/4 + y^2/9 = 1
I replaced x with 2u and y with 3v.
I got u^2 + v^2 = 1.
I let u^2 + v^2 = r^2.
r^2 = 1
sqrt{r^2} = sqrt{1}
r = 1
This tells me the bounds of r to be 0 to 1. The bounds of theta are 0 to 2pi.
dA = rdrdθ
The function x^2, I replaced by (2u)^2 = 4u^2.
I found the Jacobian to be 6.
The double integral set I came up with is
S S 4u^2 6 rdrdθ, where the inner bounds are r = 0 to r = 1 and the outer bounds are θ = 0 to θ = 2pi.
I then pulled out the constant 6.
6 S S 4u^2 r drdθ
When I evaluate the double integral, I cannot finish the problem. Shouldn't rdr be replaced with du? If this true, then the inner bounds should be in terms of u not r. I would like someone to tell me where I went wrong and to set up the correct double integrals for this problem. Do not evaluate the integrals.
9x^2 + 4y^2 = 36.
9x^2 + 4y^2 = 36
x^2/4 + y^2/9 = 1
r^2 = 1
sqrt{r^2} = sqrt{1}
r = 1
dA = rdrdθ
6 S S 4u^2 r drdθ
