Change of Variables of f(x+y) (In Multiple Integrals)
In summary, the problem asks to compute the integral of sin^2(x+y)/(x+y) over the triangular region with vertices (0,1), (1,0), and (0,0) by making an appropriate change of variables. The hint suggests using problem 24 in section 15.9 of Stewart Calculus Early Transcendentals. The solution involves letting u = x + y and v = x, and the final integral is evaluated as \int_0^1\int_0^u f(u)\,dvdu, where f(u) is the function being integrated over the region.
Jadehaan
24
The problem is as follows: Let T be the triangle with vertices (0,1), (1,0), (0,0). Compute the integral [tex]\int\int[/tex][tex]\frac{sin^{2}(x+y)}{(x+y)} dxdy[/tex] by making an appropriate change of variables. (Hint: check #24 Section 15.9)
Problem 24 in 15.9 of Stewart Calculus Early Transcendentals: Let f be continuous on [0,1] and let R be the triangular region with vertices (0,1), (1,0) and (0,0). Show that
[tex]\int\intf(x+y)dA[/tex] [tex]=\int_{0}^{1}uf(u)du[/tex]
I am confused at what values I should assign u and v in order to change the variables appropriately. Assuming the answer to #24, I obtained the solution to be (1/2)-(1/4)sin(2)
Thanks for any help or tips that point me in the right direction,
Jim
The key to #24 is the fact that the side of the triangle not on one of the axes has the equation x + y = 1. That suggests letting one of the variables by x + y. And there is no reason to change the other variable, so try:
u = x + y
v = x
The corners of the xy triangle go to (u,v) like this:
(0,0 ) --> (0,0)
(1,0) --> (1,1)
(0,1) --> (1,0)
Your exercise is to show that
[tex]\int\int_A f(x+y)\,dA = \int_0^1uf(u)\,du[/tex]
Notice on the right side, what would normally be a double integral has been integrated in the v variable (the one that isn't in the f()) already, so set up the change of variables that way. The way we set it up, the non-x+y variable is v also. Since |J| = 1 I will leave the Jacobian out. Our vu limits become:
[tex]\int_0^1\int_0^u f(u)\,dvdu[/tex]
Now you can do the inner integral without knowing f.
Got it, thanks!
Related to Change of Variables of f(x+y) (In Multiple Integrals)
1. What is the purpose of changing variables in multiple integrals?
The purpose of changing variables in multiple integrals is to simplify the integration process by transforming the original region of integration into a simpler shape or coordinate system. This can also help in evaluating integrals that would otherwise be difficult or impossible to solve using the original variables.
2. How do you determine the new limits of integration when changing variables in multiple integrals?
The new limits of integration can be determined by substituting the new variables into the original limits of integration and solving for the corresponding values. This can also be done graphically by plotting the original region of integration in terms of the new variables.
3. What is the method for changing variables in double integrals?
The method for changing variables in double integrals involves substituting the new variables into the integrand and the limits of integration, and then evaluating the integral using the new limits. This is also known as the Jacobian transformation.
4. Can you change variables in triple integrals?
Yes, variables can also be changed in triple integrals. The same method of substituting the new variables and evaluating the integral using the new limits applies, but the Jacobian transformation will involve a 3x3 matrix instead of a 2x2 matrix.
5. Are there any restrictions on the variables that can be changed in multiple integrals?
Yes, there are certain restrictions on the variables that can be changed in multiple integrals. The new variables should be continuous and one-to-one functions of the original variables, and the Jacobian determinant should not be equal to zero in the region of integration.
