Change of variables on autonomous systems solutions
In summary, the conversation discusses how to show that given the solution to an autonomous system with equations involving x and y, the solution can also be expressed with a change of variables. The change of variables is shown to be valid by using the chain rule for derivatives.
GlassBones
Given that ##x=\phi (t)##, ##y=\psi(t)## is a solution to the autonomous system ##\frac{dx}{dt}=F(x,y)##, ##\frac{dy}{dt}=G(x,y)## for ##\alpha < t < \beta##, show that
##x=\Phi(t)=\phi(t-s)##, ##y=\Psi(t)=\psi(t-s)##
is a solution for ##\alpha+s<t<\beta+s## for any real number s.
I noticed ##\alpha+s<t<\beta+s \equiv \alpha<t-s<\beta##. I'm thinking to do change of variables. But don't really know how to do that.
Notation wise does this makes sense ##\frac{dx}{d(t-s)}##.
Hint: Chain rule for derivatives.
Related to Change of variables on autonomous systems solutions
1. How do you define a change of variables on autonomous systems solutions?
A change of variables on autonomous systems solutions refers to the process of transforming a system of differential equations into a new system using different variables. This transformation is often used to simplify the equations and make it easier to find solutions.
2. What is the purpose of a change of variables on autonomous systems solutions?
The purpose of a change of variables on autonomous systems solutions is to make the equations easier to solve. By transforming the equations into a new system with different variables, it may be possible to find a solution that was not apparent in the original system.
3. How do you determine which variables to use for a change of variables on autonomous systems solutions?
The choice of variables for a change of variables on autonomous systems solutions depends on the specific system of equations and the desired outcome. Generally, the new variables should simplify the equations and make it easier to find a solution. This can be achieved by using variables that are related to the original variables in a simple and consistent way.
4. Can a change of variables on autonomous systems solutions affect the behavior of the system?
Yes, a change of variables on autonomous systems solutions can affect the behavior of the system. By transforming the equations into a new system with different variables, the properties of the system may change. This can lead to different solutions and different behaviors of the system.
5. Are there any limitations to using a change of variables on autonomous systems solutions?
Yes, there are limitations to using a change of variables on autonomous systems solutions. The transformation may not always be possible or may result in a more complex system of equations. Additionally, the new variables may not accurately represent the original variables, leading to inaccurate solutions. It is important to carefully consider the limitations before using a change of variables on autonomous systems solutions.
