- #36
- 24,488
- 15,021
It doesn't matter which force accelerates the charge. Any accelerated charge sends out electromagnetic waves, no matter how it's accelerated.
Agree, but do you know what happens about the electric induction field if the acceleration is produced mechanically?vanhees71 said:It doesn't matter which force accelerates the charge. Any accelerated charge sends out electromagnetic waves, no matter how it's accelerated.
Won't there will be different net fields in the region for each case?tech99 said:Agree, but do you know what happens about the electric induction field if the acceleration is produced mechanically?
This might help if you like to see equations rather than diagrams and words;-vanhees71 said:It may be a stupid question, but what is an "electric induction field"? There is one electromagnetic field whose sources are electric-charge and -current densities ##\rho## and ##\vec{j}##.
Not surprising, at least to me. Squaring theory with empirical data for rf is I guess not always easy. Anechoic chamber? Also, I used theoretical analyses based on an arbitrarily short dipole ## (<< \lambda/2). ## The results are quite different with a ## \lambda/2 ## antenna, with phase being required in consideration in determining the magnetic vector potential etc.tech99 said:This is just my own take on the matter of the electric fields of a dipole. I made some measurements of the fields around a dipole antenna and found something slightly different.
If we approach the centre of the antenna on the equatorial lane, the E field increases with 1/r until we are approx lambda/5 from the antenna, then levels off and remains constant until we almost touch. When we almost touch we see the very local field across the feed-point gap. However, if we approach the ends of the dipole from any direction we see the very fast local increase, which might be 1/r^3 but to my crude measurement looked more like 1/r^2.
When we are close to an antenna, not only do we see the type of behaviour described, but we also tend to see the "radiation near field" effect, where the radiation tends to be parallel to start with, and even with a simple dipole this seems to occur closer than about lambda/5.
The magnetic field, on the other hand, tended always to increase with 1/r, as does that from a non radiating long conductor, and continued to increase this way right up to the wire in the equatorial plane. It fell to zero at the ends of the dipole. This measurement is not in accordance with the theory I have read.
